Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #321
I'm 3 states from Messicks and I still order from them. Ocassionally, their ship cost is outta line but they always have what I need and I can have it in 2 days if I'm down.
My local dealer(s) don't stock ****te even thought Kubota's distribution center is only 150 miles from here (Greater Columbus, Ohio), Messicks is quicker. Glad they hardly ever break.
   / Damaged block installing block heater L5240 #322
Sometimes convenience has its price.
We were around 1hr short of having the engine assembled today. Will continue on Tuesday evening.
The Fred: this is the picture you asked for..
We had lots of fun putting the pieces back together. Wasn't too bad.
We actually finished mounting the head before calling it a day. Just need to install the push rods, rocker arms, valve cover and oil pump/oil pan.
Aiming to get it back in the frame by the end of the week and the two halved back together next weekend.
   / Damaged block installing block heater L5240 #327
No greater feeling than seeing an engine rebuild cone together.
It's. Only minimized by the feeling of thinking, "what did I miss?".
   / Damaged block installing block heater L5240 #328
Lookin good!
Fred
This picture is shown before we re-installed the crank. We are looking at it from the rear of the block on the flywheel end. As you can see, the only main bearing that stays with the machine is at the front of the engine. That is the one I had to replace and it is not a two piece bearing. It pressed out and back in.
The other 4 bearings all bolt into a "yoke" and then the yoke is bolted to the block with one bolt from the bottom of the engine in between each cylinder.
   / Damaged block installing block heater L5240 #330
Here's hoping you're using lots of assembly lube on the dry parts during assembly.
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
207279 (A52708)
207279 (A52708)
Wolverine Quick Attach Post Hole Digger w/ Augers (A59814)
Wolverine Quick...
John Deere 4510 (A53317)
John Deere 4510...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
