Cutting thick (2") Steel
/ Cutting thick (2") Steel #22
How about some pix of that truck?
times two
amazing
I try calculating flotation with most builds, dead weight only serves as ballast.
on topic = oxy/fuel would be my choice .... 1/2" and thicker, actually oxy/fuel for anything other than sheet metal.... for me anywho...
twas wondering what was the 2 inch thick material was for. Some serious drop loading on the truck, I'd guess??? unless the bed itself was ballast???
MANITOWOC
/ Cutting thick (2") Steel #23
I remember seeing a Unimog in the 70's that had 2" plate for ballast and a deck. I'll bet that's what's going on here.
Here is a picture of the truck and one of the holes I cut out. The torch did well but it was hard to get a clean cut and be able to remove the piece. Took about 4 hours. I have three more pieces to remove hopefully I will get better and go faster with those.
The weight is just to hold the truck down. The unit on the back is a big hammer used for seismic exploration. It beats on the ground with tremendous force and if the truck does not weigh enough the truck will bounce when the hammer hits. The unit is capable of a lot higher output than we ever use or need so we are reducing the weight of it to get the truck under CDL limits.
Another pic of truck
/ Cutting thick (2") Steel #26
If you can, and if you have a rose bud, preheat the bottom side. Will make it a lot easier on you!;)
/ Cutting thick (2") Steel #27
In Canada they are called Thumper Trucks.
[ame=http://www.youtube.com/watch?v=Kpda8NJAGSs&feature=player_embedded]Thumper Trucks in New Brunswick... [HD] - YouTube[/ame]
Neat thing is they can all be synchroized to thump together, then they use geophones to pickup the sound reflections from below.
People don't like siesmic crews using explosives anymore.
People call those Thumpers but really they are not they are vibrators. No weight is picked up and dropped like a true thumper. The base plate on a vibrator is in constant contact with the ground and just shakes. They can be syncronized as the frequencies they sweep through are computer controlled. A true weight drop thumper can not be syncronized. They have tried and can't get the mechanical aspects of it to sync up time wise.
Dynamite is still widely used. We use the thumper more but use dynamite all the time as well. Often the dynamite is less intrusive as they have some really small drills that don't require near the clearing as you need to get a thumper or vibe through.
/ Cutting thick (2") Steel #29
CDL limits don't go by weight.
You will need to have the GVWR changed to get under CDL.
I have that covered. The bed was mounted on a truck with a 33k gvwr I just moved it to a truck with a 25999 gvwr.
/ Cutting thick (2") Steel #31
I'm a real hack when it comes to O/A burning. I've worked with a few guys over the years that could burn better free hand than I could with a tractor torch.
When I set up a torch to burn I like to get the cutting cone as long as possible. 99 times out of 100 I only need to press the cutting lever an 1/8 inch or so. When I do find the sweet spot the flame sounds like a small jet engine. :cool:
SA, what king of torch is that? The tip looks really tapered?
/ Cutting thick (2") Steel #32
Victor, the cutting head is a model, CA-1050. Mixing chamber is 3150 T-76687.
/ Cutting thick (2") Steel #33
Monkeywrench, great vid......thanx for sharing that..:thumbsup:
/ Cutting thick (2") Steel #37
Ah. Carry on then. :D
You may get the gross weight under 26999 lbs, BUT you will still have to comply with the annual safety and that yellow sticker and also log book rules. 9921 lbs requires annual safety and log book.
/ Cutting thick (2") Steel #38
Huh?
In TX. ;)
/ Cutting thick (2") Steel #39
Maybe licensing requirements are different in TX to the rest of North America. ;)
I was just on the Texas D.O.T. website and couldn't find the section I was looking for regarding license plate and vehicles weighing more than 10,000 lbs. Other than commercial motor carriers which I know you are not.You may be a commercial motor vehicle, but you are not a motor carrier, because you don't carry goods or people for compensation.
So that being said, I will retract my previous statemet aka STFU and bow out gracefully.
Sorry for hijacking the thread.
I deal with the DOT stuff daily and have a DOT number and run 5 trucks.
In Texas operating in state commercial or not as long as you are under 26k you don't need to do anything special. If you are over 10k and operating interstate then you need to the commercial inspection stickers, medical card, fire extinguisher, road triangles, log book, etc but no CDL until you are over 26k.
We have DOT numbers and are fully compliant with all requirements for interstate operation for over 10k but under 26k. However when we are operating in Texas we don't have to fool with the log books or hours of service etc.
More info coming soon (A61569)
More info coming...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
UNUSED WOLVERINE TDB-11-72W 72" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
