Cutting off an ORC
/ Cutting off an ORC #1
RickinVA
Berryville, VA
Ford 8N
I need to cut off an ORC from my 8N. I don't have a welder so guessing I need to by some sort of grinder or cutting wheel. Would appreciate advice on tools and technique.
Thanks,
Rick
/ Cutting off an ORC #4
I'd use an angle grinder with cutting wheel if it came to that. Are you sure you can't get it removed? The ones I used had zerk fittings on each side of the ORC cylinder, and the zerks are removed to access a roll pin that can be punched through the tractor's PTO shaft.
/ Cutting off an ORC #5
ORC - good to know. I'm real careful about cutting anything off. Especially when I don't know what it is. Shades of John & Lorena Bobbitt.
/ Cutting off an ORC #6
Thanks,
Rick
Why does it need to be CUT off?
My fault. Lack of grease. Can't turn the outer part to line up the zerk holes with the role pin.
/ Cutting off an ORC #8
I would first pull the zerks and fill it with it with something like liquid wrench, then, work on it to get it loose. Heating it with a simple propane torch and tapping it with a hammer would speed things up.
Thanks. I've tried PB Blaser and a hammer. Will try some heat. Really surprised it locked up this tight. When I put a rod through the hole on the end and try to turn it with the PTO engaged it just turns the engine.
/ Cutting off an ORC #10
My last project was going very poorly, untill i hit it with some heat and, after good and hot, hit it with pb blaster. I think the fast cooling draws it in and breaks the rust seal. Good luck.
Thanks. I read somewhere heat near the PTO seal could be a bad idea. Thoughts?
/ Cutting off an ORC #12
If you just heat the outer portion with a small torch, I doubt you will get much heat transfer to the inner shaft.
72in. Fork Extension (A64553)
72in. Fork...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2022 EZ-GO ELITE...
TAYLOR 2R MULI-PASS HARVESTER (A64278)
TAYLOR 2R...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
