Cutting off an ORC
/ Cutting off an ORC #1
RickinVA
Berryville, VA
Ford 8N
I need to cut off an ORC from my 8N. I don't have a welder so guessing I need to by some sort of grinder or cutting wheel. Would appreciate advice on tools and technique.
Thanks,
Rick
/ Cutting off an ORC #4
I'd use an angle grinder with cutting wheel if it came to that. Are you sure you can't get it removed? The ones I used had zerk fittings on each side of the ORC cylinder, and the zerks are removed to access a roll pin that can be punched through the tractor's PTO shaft.
/ Cutting off an ORC #5
ORC - good to know. I'm real careful about cutting anything off. Especially when I don't know what it is. Shades of John & Lorena Bobbitt.
/ Cutting off an ORC #6
Thanks,
Rick
Why does it need to be CUT off?
My fault. Lack of grease. Can't turn the outer part to line up the zerk holes with the role pin.
/ Cutting off an ORC #8
I would first pull the zerks and fill it with it with something like liquid wrench, then, work on it to get it loose. Heating it with a simple propane torch and tapping it with a hammer would speed things up.
Thanks. I've tried PB Blaser and a hammer. Will try some heat. Really surprised it locked up this tight. When I put a rod through the hole on the end and try to turn it with the PTO engaged it just turns the engine.
/ Cutting off an ORC #10
My last project was going very poorly, untill i hit it with some heat and, after good and hot, hit it with pb blaster. I think the fast cooling draws it in and breaks the rust seal. Good luck.
Thanks. I read somewhere heat near the PTO seal could be a bad idea. Thoughts?
/ Cutting off an ORC #12
If you just heat the outer portion with a small torch, I doubt you will get much heat transfer to the inner shaft.
Beverage Truck Body (A64556)
Beverage Truck...
Ford 8N Tractor (A66408)
Ford 8N Tractor...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
(4) Heavy-Duty Pipe Gates (A66408)
(4) Heavy-Duty...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
