Cutting off an ORC
/ Cutting off an ORC #1
RickinVA
Berryville, VA
Ford 8N
I need to cut off an ORC from my 8N. I don't have a welder so guessing I need to by some sort of grinder or cutting wheel. Would appreciate advice on tools and technique.
Thanks,
Rick
/ Cutting off an ORC #4
I'd use an angle grinder with cutting wheel if it came to that. Are you sure you can't get it removed? The ones I used had zerk fittings on each side of the ORC cylinder, and the zerks are removed to access a roll pin that can be punched through the tractor's PTO shaft.
/ Cutting off an ORC #5
ORC - good to know. I'm real careful about cutting anything off. Especially when I don't know what it is. Shades of John & Lorena Bobbitt.
/ Cutting off an ORC #6
Thanks,
Rick
Why does it need to be CUT off?
My fault. Lack of grease. Can't turn the outer part to line up the zerk holes with the role pin.
/ Cutting off an ORC #8
I would first pull the zerks and fill it with it with something like liquid wrench, then, work on it to get it loose. Heating it with a simple propane torch and tapping it with a hammer would speed things up.
Thanks. I've tried PB Blaser and a hammer. Will try some heat. Really surprised it locked up this tight. When I put a rod through the hole on the end and try to turn it with the PTO engaged it just turns the engine.
/ Cutting off an ORC #10
My last project was going very poorly, untill i hit it with some heat and, after good and hot, hit it with pb blaster. I think the fast cooling draws it in and breaks the rust seal. Good luck.
Thanks. I read somewhere heat near the PTO seal could be a bad idea. Thoughts?
/ Cutting off an ORC #12
If you just heat the outer portion with a small torch, I doubt you will get much heat transfer to the inner shaft.
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
Standing Horse Statue (A65583)
Standing Horse...
