CUT vs CTL
/ CUT vs CTL
Got it going. Turns out it was my fault, sort of. The cold start solenoid and engine stop solenoid have the same plug, and I got them switched when I put the harness back in. That explains why it would start after cooling down, then die. Yes the fuel pump was working, but that is good to know. Thank you.
I fixed the stuck throttle pedal assembly. Replaced the throttle cable. Cleaned it all up. Tested it out, it is a beast in the mud. Worked well enough for me to get stuck. Twice. I seem to have to find my limits the hard way, and it does have limits.
iDrive TDS-2010H...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
