Cut off blade issue...
/ Cut off blade issue... #1
/pine
Super Star Member
The blade edge on my 14" makita cut off saw has worn off on the inside (due to trying to make shave cuts)...and the rounded off side wants to migrate to the outside as it cuts...leaving an out of square cut...
What is the best way to dress the edge on an abrasive blade?...I was hoping to find a simple dressing tool but no joy...
any suggestions other than just eyeballing it with a dressing stone?
Can you turn the blade around?
I thought about and I can...but I'm sure I'm going to have a need to be making more of the same type of problematic shave cuts...
/ Cut off blade issue... #5
Toss it, get a new 14' blade and use a grinder to shave off a tiny bit. Mark it all around first with a square, if you need the accuracy. Seriously. Abrasive blades do not like that at all, and can blow apart from being bent when they are only partially in a cut. Assuming I understand what you are doing correctly.
/ Cut off blade issue... #6
Years ago I built this 18-inch, 7 1/2 horse power chop saw. I don't remember breaking any blades with it. But I worked in a Fab shop that had one just like it. When the blades would break, if the chunks hit you in the chest, it would almost knock you down! :eek:
/ Cut off blade issue... #7
Now thars a SAW!!!:eek:
/ Cut off blade issue... #8
I bought a similar saw at an auction for $160. Mine is a 20" with a 10hp motor. These big saws make a little 12" portable saw look like children's toys. I need to rework the table. Whoever build it put the stop which is a 5" piece of angle iron upside down. image-3454060587.jpg
/ Cut off blade issue... #10
I believe the abrasive saws on our old rail changers where in the 22-24 in dia range. They would cut thru a piece of rail in about a minute or 2. When cutting you had to put your body weight on the saw and ride it down thru the rail. Now days they use the gas powered chop saws, with 14in blades, some have 16in bldaes. You only get about one cut and maybe a part of a second cut per blade.
/ Cut off blade issue... #11
I remember doing that.:laughing:
The fab shop I worked in. Had the chop saw out in an open bay with all the metal racks. Above the chop saw was clear fiberglass roof panels. There were several holes in these clear panels from when the blades broke. I never used that chop saw with a clear face shield on, I always wore my welding hood!
1762 (A58375)
1762 (A58375)
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
More info coming soon (A61574)
More info coming...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
