Custom UTV
/ Custom UTV #81
kdlklm said:
that's a good information site, but unfortunately they don't have the size that I need. I need 1.5 ID to 1.75 OD. I was hoping to get a tube of it and just cut the length I need. But that's proving to be difficult. But it does appear that plastics are the way to go.
UHMW-PE
http://www.plasticsintl.com/uhmw-rod.html
They don't appear to stock in tube, but they do have rods of 1.75". Drill the ID, and you are set. 24" for $15.38 is reasonable enough. This stuff is very durable and the PE is temp resistant. Check the specs, I think this should work.
/ Custom UTV
it shouldn't be too difficult to put it on the lathe. It does cut real nice. It might be my only option To use a plastic material.
/ Custom UTV #83
Yeah the nylon should work well for this application.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
Sakai SW354 (A64126)
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2011 PETERBILT 367 (A65643)
2011 PETERBILT 367...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
