Custom UTV
/ Custom UTV #81
kdlklm said:
that's a good information site, but unfortunately they don't have the size that I need. I need 1.5 ID to 1.75 OD. I was hoping to get a tube of it and just cut the length I need. But that's proving to be difficult. But it does appear that plastics are the way to go.
UHMW-PE
http://www.plasticsintl.com/uhmw-rod.html
They don't appear to stock in tube, but they do have rods of 1.75". Drill the ID, and you are set. 24" for $15.38 is reasonable enough. This stuff is very durable and the PE is temp resistant. Check the specs, I think this should work.
/ Custom UTV
it shouldn't be too difficult to put it on the lathe. It does cut real nice. It might be my only option To use a plastic material.
/ Custom UTV #83
Yeah the nylon should work well for this application.
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
