Custom UTV
/ Custom UTV #61
The picture I showed was from a low slung hot rod. Many coil sprung 4x4's use them and they are then above the axle. Range rover being one of the first examples, except that they had a slightly more complicated 3rd arm in the middle with a fancy ball joint. But it again only worked because they had a rigid axle connecting the 2 wheels together.
You can't use a motorcycle rear trailing arm design on a 4 wheel vehicle. Motor cycles lean into corners so they do not have side loads the way a 4 wheel vehicle will have which does not lean. The motorcycle style design would quickly be destroyed in your application. You need to have your suspension design absorb all lateral and torsional forces. That could be all of the vehicle weight on 1 wheel at a 45 degree angle in some cases. Not exaggerating..
The simplest solution would be to use something like a straight trailer axle (2 hubs connected by a straight tube), use 2 radius rods like what you have in mind + 1 panhard rod behind the tube of the axle. The radius arms control the fore and aft forces, resist the torsion of the drive system and braking as well as the vertical suspension reactions. The panhard rod controls any lateral movement. Your radius arms would just have to attach to the top and bottom of the axle "tube" to be able to resist the torque. You may be able to get such radius arms ready to go from a vehicle like the Land rover. This is what they look like
/ Custom UTV #62
What if you made a tilt deck similar to this one with a vertical cylinder (or cylinders) in the front corners to lift it up?
You could add a flip up front with a pair of cylinders up there if you needed a longer ramp or something to restrain your chair.
Speaking of which, how are you planning to planning to keep your chair in place as you are bouncing and rocking around?
Aaron Z
/ Custom UTV
I can't have anything underneath the machine, there just won't be enough ground clearance if I do, because the front-end kneels down almost 8 inches, to allow the chair in and out. Unless I'm misunderstanding you
/ Custom UTV
Aaron Z
I've tried the tilt bed, and lowering floor ideas several times. But they just don't seem to work very well with a small amount of space inside the machine. It looks much more functional on a large flat surface like a trailer. There are a number of different electric tiedown systems that I can purchase. I haven't decided exactly what yet. But that's the last my concerns, I just want to have something that moves.
/ Custom UTV #65
kdlklm said:
would that not affect my ground clearance, I want to keep the middle as open as possible. One thing I have looked at is a single-sided swing arm that are used on motorcycles. I could build something like that.
Yes this is what I'm talking about. Same as the sketch I attached. The arms should attach to a tube that runs the width of the vehicle. This will be very strong. Not sure what you would use for bearings though....
/ Custom UTV #66
What if you made an arc shaped slit in both sides and had a rod stick through to connect to a pair of rams?
Something like:
Makes sense.
Aaron Z
/ Custom UTV
going with an air ride system will kill two birds with one stone, it will give me suspension and allow the front-end to kneel down. Plus there's an option for a self leveling system. Which would be nice on slopes. The cost of the air ride system is making me simplify the system.
/ Custom UTV
I see which are saying, I just need to find a way to get it passed the brackets and the shock absorber.
/ Custom UTV #69
OK, this picture shows the old layout with 2 radius arms + the triangular upper arm (which would be replaced by the panhard rod). If you imagine the coil springs being replaced by air bags, the basic idea would fit. These vehicles have at least 8" of articulation.
So in your case the hardware is simplified. Instead of an axle/differential, you have a tube. You have 2 side mounted radius arms, like what you originally had in mind, just the pivot has to incorporate a pair of elastomeric bushings to allow for some lateral movement. Most leaf sprung vehicles have these bushings for the same reason, the leaf spring has to twist when one wheel is raised and not the other. There is 1 panhard rod connected to the chassis on 1 side and the axle tube on the other side. So now the axle can go up and down and is constrained side to side and is very strong.
Somewhere, you still need drive to the wheels, and the means to allow the wheels on one side to turn faster than the other side when turning. Using a small axle from passenger car could be a relatively simple solution, you drive the differential with a hydraulic motor and it already provides the differential action. Its a pity I have no cad system at home, since whipping up a design like this would not take long.
/ Custom UTV
I made a few changes to the pivot arms, I added some more bracing to help the sideload when turning and being on slopes. just looking for some feedback as to whether it will be strong enough or not. The main shaft in the back that holds it all together, is 1.5 inches. It goes completely through the back of the machine to the other side.
/ Custom UTV #71
Man, that's the coolest looking toy in the world!
/ Custom UTV
I'm looking for some opinions on which would be the best bushings to use for the front suspension. I've attached a photo that shows where the front suspension mounts and should be self-explanatory as to how it works. What would be the best materials for this type of application. I don't think it'll be too high of heat, but it will be quite rapid movement if the train is rough.
/ Custom UTV #74
If your talking about the pivot point, I would think a needle pin bearing would be best for smooth operation and load capacity,
/ Custom UTV #75
tail gate / ramp that drops down. for access of wheel chair.... at the very end of the gate come up say 1 foot with a piece of metal. and then an "actuator" vs a hydraulic cylinder possibly. with a quick removable pin. and then attach actuator back on the unit itself. i say actuator, due to possibly "not as heavy" in case something happen to motor of UTV, or like. and person might be able to remove pin and lift actuator out of the way, and let tail gate down. to get out of the UTV. actuator being 12v electric. you could place a cheap little flip switch right at tail gate / ramp. that would let ramp up or down. and avoid costly space of running hydraulic hoses. that may bend out into the area for the wheel chair to enter / exit the UTV.
/ Custom UTV #77
kdlklm said:
Yes I am referring to the pivot point.
Look into what they use on VW suspension arms. ... I know dune buggies have a similar design.
You maybe able to use a sleeve and rod made from Steel. And then just keep greased with a zerk.
Of course bearings could be installed too...
/ Custom UTV
it seems like urethane bushings are used a lot on pivot points. They are maintenance free, but I'm not sure how long it would last on an application like mine. Does anybody have any experience with them.
/ Custom UTV
that's a good information site, but unfortunately they don't have the size that I need. I need 1.5 ID to 1.75 OD. I was hoping to get a tube of it and just cut the length I need. But that's proving to be difficult. But it does appear that plastics are the way to go.
