Cub Cadet Hydrostatic Oil
/ Cub Cadet Hydrostatic Oil #41
I've had a CC 782 hydrostatic for 25 years or so. I've changed the fluid twice with regulation CC fluid. No problems. I don't think there is any reason to go to anything else.
Mike
Winchester VA
/ Cub Cadet Hydrostatic Oil #42
</font><font color="blue" class="small">( ..Now I know why I left this board before. This will be my last post. I came here to help customers and give direct information.
I apologize if I step on anyones toes.
Good day.
)</font>
Lazy1- It's your decision if you want to bail out or not, but don't do it on account of this thread. We just wanted to know of an aftermarket alternative to CC Drive System Fluid Plus. You don't know if one. No big deal man! /forums/images/graemlins/wink.gif
G/luck
Joel
/ Cub Cadet Hydrostatic Oil #43
as far as i see it if the oil meets or excedes cc spec.they have noting to say /forums/images/graemlins/grin.gif
/ Cub Cadet Hydrostatic Oil #44
</font><font color="blue" class="small">( I've had a CC 782 hydrostatic for 25 years or so. I've changed the fluid twice with regulation CC fluid. No problems. I don't think there is any reason to go to anything else.
)</font>
I agree, to a point, but..... The fluid in question is $32 a gallon and some of these machines need 5 gallons when serviced.
When I posed this same question earlier it was suggested I should have bought a Murray at Walmart, what, you don't see the connection?
This is, at times, a very disturbing aspect of this board, that you pose a question and put on your flak jacket.
Some people feel compelled to attack those that don't see their point of view. Part of the problem is some folks just have no tact. Or maybe they have just never encountered a dissenting opinion.
Whatever, when I see someone getting flamed over a honest inquiry or they are just trying to help someone else, I try to remember it's probably one out of 1000 members that just have no clue how abrasive they are.
Curt
/ Cub Cadet Hydrostatic Oil #45
</font><font color="blue" class="small">( as far as i see it if the oil meets or excedes cc spec.they have noting to say )</font>
But that's the rub. Cub does not make that information available.
/ Cub Cadet Hydrostatic Oil #46
OK, Do you see the issue here?
Cub is stating that you have to use certain type of fluid for warranty coverage. They cannot turn against their warranty statement and say "well, if you want to use something else use this"
If they did that they would have to warranty everything that happend to anyones transmission. Anyone could say " well, Cub said I could use this type"
I understand your frustration over the price. But unfortunately the recommended fluid type is Cub Cadet and Hydro-Gears decision.
Cub Cadet and its dealers cannot give out any alternative fluid types.
/ Cub Cadet Hydrostatic Oil #47
</font><font color="blue" class="small">( I dont have a chip on my shoulder. Im just here to explain it to you guys.
Try to save you guys some time and trouble. But you guys want to argue about it. You can't argue with a manufacturer or a written warranty statement.
I apologize if you interpreted my posts that way.
BUt no manufacturer is going to give you a recommended fluid because you choose not to pay for it.
I stated before you are free to use what you like. However, if a problem occurs and the dealer or manufacturer finds out you used a cheap fluid that caused the problem, you will be responsible.
I was just trying to save you guys the hassle and trouble.
Use the recommended fluid until the factory warranty is up, then you are free to use what you like.
Good day.
)</font>
I think your wording is what everyone is arguing about. "CHEAP" doesn't always mean bad and "EXPENSIVE" doesn't always mean good. If you use an oil that is not suitable for the Hydro drive for whatever reason, viscosity, additives, temp limits etc. and it causes the failure your warranty is void. If I use a 50 cent/quart hydraulic oil and the drive fails from a manufacturing defect CC would have to prove that the oil caused the failure before they could void the warranty. That's the main purpose of the Moss Magnusen Act which allows me to use Fram or Purolator filters in my GM car and GM can't vois my warranty for that reason alone.
Bob B.
/ Cub Cadet Hydrostatic Oil #48
Is it Cub or the manufacture of the unit that does not share info. Rozett, I called my local dealer for an air filter price on my 7360 and for a 8454. $78.00 for the 7360 and $26.00 for the 8454. What is the difference, both are Cub Cadets. Mits vs. Kioti. That proves to me Mits is slaming you, dealer and Cub on parts. I still don't think it is the dealer. Cub Tech gave us the cost on the 7360 filter threads ago. Its Mits. As for the oils, when GM says it wants Mobil 1 or equal in its high out put engines it means it. If there is a failure an oil sample will be taken. If the correct lubricant is not in the engine there is no warranty. So Cub Tech is telling the straight up.
/ Cub Cadet Hydrostatic Oil #49
Dealer cost on the mits filter for the 7360 is just below $60 dollars. As a dealer, we have tried many times to find a cross reference for these filters. The 7205 cub tractor is now in the mahindra linup as the 2015 tractor. The air filter from Mahindra now is just a couple dollars cheaper. The Cub 7305 tractor is now in the Mahindra lineup as the 3015 tractor and the air filter is again, just a couple of dollars cheaper. The Mits parts are the expensive ones. If anyone has found an aftermarket filter for these tractors, please let me know. I know the Cub old style metal case filter for the 7205 now crosses to a Kubota filter number and is much cheaper through an aftermarket company like Oregon. This is the only one i've found.
/ Cub Cadet Hydrostatic Oil #50
So what did you guy's come up with for the replacement fluid?
/ Cub Cadet Hydrostatic Oil #51
</font><font color="blue" class="small">( So what did you guy's come up with for the replacement fluid? )</font>
I gave up on it /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif. Search this forum for 'drive system fluid plus' or the likes, for threads on this topic. I may go with Mobil-1 20w-50 @ 300hrs or so, which will be about 6-7yrs from now /forums/images/graemlins/grin.gif.
G/luck
Joel
/ Cub Cadet Hydrostatic Oil #52
Hope you don't mind a newbie jumping in here. I saw this thread and like with many this is a subject of interest.
I'm also put off buy Cub's price on this fliud and would like to have a choice. Time for the first filter change last month and I had to pay $13 for a qt of this stuff. There can't be that much magic in this stuff to warrant that kind of price.
I see where Lazy said only need to change fliud every 400 hrs. Well, not according to my manual. After initial change, filter every 50 hrs and fluid every hundred.
Tractors 2 yrs old now so when it's time for another change, I'll be looking into an alternate as I'm not about the pay $13/qt to do a complete change.
/ Cub Cadet Hydrostatic Oil #53
I can't remember what all I went through to arrive at this conclusion. I found a spec number or something and was able to cross it over to regular HyTrans that is used in many large tractor systems. It is just a hydraulic oil.
This was a few years ago, so I don't remember where I found the spec or anything but I was convinced at the time that this was the correct stuff. I bought a five gallon bucket of the stuff for what about 3 quarts would cost from Cub Cadet.
The mower I was getting it for is a 2145.
Good luck,
Doc
/ Cub Cadet Hydrostatic Oil #54
</font><font color="blue" class="small">( Hope you don't mind a newbie jumping in here. I saw this thread and like with many this is a subject of interest.
Tractors 2 yrs old now so when it's time for another change, I'll be looking into an alternate as I'm not about the pay $13/qt to do a complete change. )</font>
It makes you wonder if they changed the maintenance schedule just to sell more supples. Nahhh, they wouldn't do that. My old 1450, which used the reddish Hytran fluid called for a filter every 100 hours and I don't think they ever said the fluid had to be changed. I used to change the filter around 100 hours, using a common (cheap) Fram PH3600 and the only fluid change was at 924 hours when I pulled the trans to replace a leaking gasket between the trans and differential. The 1450 had 1100+ hours on it and was still running great, when I traded it in for my 3235. Now I'm using synthetic trans oil, which is supposed to last longer than the old stuff, and am supposed to change the filter every 50 hours and fluid every 100 hours. I DON'T THINK SO!
Bob B.
/ Cub Cadet Hydrostatic Oil #55
I agree Bob! changed my oil on my 3204 at 150 hrs, and it looked as good as new...i'm doing 300 hrs or more for now on!!
Duc
/ Cub Cadet Hydrostatic Oil #56
Hey Duc, what you doing here? /forums/images/graemlins/wink.gif
Somewhere in the long thread was mention of not mixing other kinds of oil with this "special" trans oil. I changed my trans filter several weeka ago and the "spilled" oil was still in the pan. A few days ago I changed the oil in my brush hog into the same pan. Those two fliud mix as well as oil and water. I can slosh the pan around but these 2 fluids just won't mix.
/ Cub Cadet Hydrostatic Oil #57
</font><font color="blue" class="small">( Hey Duc, what you doing here? /forums/images/graemlins/wink.gif
Somewhere in the long thread was mention of not mixing other kinds of oil with this "special" trans oil. I changed my trans filter several weeka ago and the "spilled" oil was still in the pan. A few days ago I changed the oil in my brush hog into the same pan. Those two fliud mix as well as oil and water. I can slosh the pan around but these 2 fluids just won't mix. )</font>
Its good to see you here as well Micky!! This place has a lot of info as well as a ton of members ....I've been posting here for a few years already -geesh where did the time go?
lots of Yanmar info too
As for the oil, I will be extending the intervals - I see no reason not to - its a key advantage of synthetic blend oils, I would assume....
/ Cub Cadet Hydrostatic Oil #58
I have a 7205 CC I just changed the fluid and put in 15-50 mobil 1.
/ Cub Cadet Hydrostatic Oil #59
Thanks for pulling up this old thread. It certainly seems that M1 15W-50 would be a good choice to replace the overpriced and mediocre appearing Cub fluid...
/ Cub Cadet Hydrostatic Oil #60
CubTech said:
:confused: Change your fluid every 400+ hours. :confused:
I'm puzzled about your statement about changing the fluid every 400 hours.
I've read my CC GT2554 owners manual from cover to cover several times searching for when to change the trany fluid in it.
The manul don't say a thing about ever changing the fluid at all .so where did you come up with 400 hours?
GIYI Skid Steer Mount Stump Grinder  (A62679)
GIYI Skid Steer...
40' New Container (A62679)
40' New Container...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
(16) Kinze Brush Meters (A65640)
(16) Kinze Brush...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
