Creepy loader
/ Creepy loader
Yeah it looks like I need to pony up for a new valve. While I'm at it I need to replace the loader valve and loader lines.
My plan with this tractor is to haul it over to Montana and clear my property and do the site prep for the buildings. I really need it to be dependable.
/ Creepy loader #32
I'd go with a new loader valve and a new lines. Not so much the lines. Just thinking of a Frontier Loader I'm all to familiar with. And if there is fluid getting past the 3point valve that's not a problem. Esp in Float. All the loader valves should be closed and any fluid to them is stopped and diverted back to the reservoir. When the 3pt. control is in Neutral it won't matter much about the weight on the 3pt. arms it still going to get stopped at the loader controls and diverted to the pump reservoir. The raise and lower of the FEL. bucket are the most used and the most pressure needed. Perfect example is a Cold water setup. Only one Dump Cyl.. It's really hard to diagnose not having it...........
Deere 335P (A53317)
Deere 335P (A53317)
TANK MANIFOLD (A58214)
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2023 Dodge Durango SUV (A59231)
2023 Dodge Durango...
