Loader Cracked bucket
/ Cracked bucket #1
atcNick
Longview, Texas
Still shopping
Can this be fixed? Thinking of getting it welded. IMG_3852.JPGIMG_3851.JPGIMG_3850.JPGIMG_3849.JPG
/ Cracked bucket #4
looks like someone quenched the welds so it would cool faster.
grind out and weld. both sides. let it cool slowly.
/ Cracked bucket #5
As herm0016 said, grind it out and weld from both sides. Grind about 2/3 of the way thru from one side, weld it up then grind back about 2/3 from the opposite side. This will assure that you get solid weld and get all the crack ground out.
A little preheat to 200F before welding would be advisable. Make sure you grind all the way to the end of the crack.
/ Cracked bucket #6
As mentioned above, V it out and weld.
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
1999 Sterling Dump Truck (A64127)
1999 Sterling Dump...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
