Loader Cracked bucket
/ Cracked bucket #1
atcNick
Longview, Texas
Still shopping
Can this be fixed? Thinking of getting it welded. IMG_3852.JPGIMG_3851.JPGIMG_3850.JPGIMG_3849.JPG
/ Cracked bucket #4
looks like someone quenched the welds so it would cool faster.
grind out and weld. both sides. let it cool slowly.
/ Cracked bucket #5
As herm0016 said, grind it out and weld from both sides. Grind about 2/3 of the way thru from one side, weld it up then grind back about 2/3 from the opposite side. This will assure that you get solid weld and get all the crack ground out.
A little preheat to 200F before welding would be advisable. Make sure you grind all the way to the end of the crack.
/ Cracked bucket #6
As mentioned above, V it out and weld.
Quick Attach Backing Plate (A65579)
Quick Attach...
IRGC40 High End Mini Golf Cart (A64127)
IRGC40 High End...
Push Type Weed Eater (A64127)
Push Type Weed...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
2011 INTERNATIONAL WORKSTAR 7300 CHEMICAL BOBTAIL (A65643)
2011 INTERNATIONAL...
