Cover Dump Trailer For Winter??
/ Cover Dump Trailer For Winter?? #1
El Wood
Michigan
JD 3320
I know there has been a lot of threads about covering trailers for the winter but I haven't been able to find one specifically for dump trailers...
Does anybody cover there's? Mine was new this year so I'm debating covering it with a tarp. I would get a small car port but there not cheap. The paint on these trailers looks very durable and they seem to be built like tanks so maybe I don't need anything. Can anyone offer advice? Here is a pic...
/ Cover Dump Trailer For Winter?? #2
No suggestions, but that is a nice trailer you got there! I plan on leaving my trailer out in the elements.
/ Cover Dump Trailer For Winter?? #3
Just make sure you have it tilted toward the rear, to prevent rain/melt water from accumulating in the closed foreward end of the trailer
/ Cover Dump Trailer For Winter?? #4
I agree. Use some block of 4x4 to secure it up slightly. Only 5 deg slope or so is all you need or you may be able to even park it on a slope. I am not a fan of covering trailers. It traps in moisture and they rust quicker. Just make sure you grease it up and touch up paint before the layup.
Chris
/ Cover Dump Trailer For Winter?? #5
In addition get the tires out of the dirt if its not parked on pavement.
Thanks for the comments! I'll leave it uncovered and make sure to get the tires off the dirt. Eventually when the barn is up, I'll build a lean-to and park it under there.
/ Cover Dump Trailer For Winter?? #7
You can use the 2x2 concrete patio slabs to raise it up off the dirt. Also put covers over the tires to stop the sun from drying them out.
/ Cover Dump Trailer For Winter?? #8
Just got a new dump trailer last week myself. So this was a timely topic. Wondering if it's worth it to purchase some tire covers to keep the UV & weather off them in the off season?
/ Cover Dump Trailer For Winter?? #9
Can not hurt.
Chris
/ Cover Dump Trailer For Winter?? #10
I have learned over the yrs that a tarp under is more important then a tarp over. As others have suggested tilt it so water doesn't sit. Covering the tires isn't a bad idea. Stopping moisture from the ground is what I worry about the most a simple tarp layed on the ground does work wonders.
/ Cover Dump Trailer For Winter?? #11
What is the problem with tires on the dirt?
/ Cover Dump Trailer For Winter?? #12
Can not hurt.
Chris
Went ahead and ordered some this morning. Kinda sucks because I've got 4 trailers with 14 tires total! But I think the covers could stretch out tire replacement intervals due to the sidewalls weather checking and possibly pay for themselves in the end.
/ Cover Dump Trailer For Winter?? #13
To protect the tires, I normally take pieces of scrap plywood and cut them to fit over (or under) the wheel wells. You just need enough to keep the sun and weather off the tires.
/ Cover Dump Trailer For Winter?? #14
The problem isn't tires and dirt it's tires and sun. One of the worst things we can do with our pieces of equipment that don't get regular use is to leave them out in the elements and yes sun will raise cain with tires.
/ Cover Dump Trailer For Winter?? #15
Moisture. Get them on gravel or better yet concrete. Wood is better than noting but I would use pavers first.
Chris
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
LOT LOCATIONS (A59914)
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
(5) 10 X 20 STEEL MATS (A64276)
(5) 10 X 20 STEEL...
