County Line(TSC) Landscape rake
/ County Line(TSC) Landscape rake #41
Looks very close to Cat Yellow
If you need touch up paint, TSC's Cat yellow, is a perfect match.
/ County Line(TSC) Landscape rake #42
That's kinda what I thought, picked a can at TSC yesterday.
Thanks for the confirmation!
/ County Line(TSC) Landscape rake #44
I should of took the advice of those who know. I used my County line landscape rake today the first time. 3 passes in and it tweaked. The metal fatigued and cracked right at the pivot point. I was moving very slow and gentle in med gear so not to apply too much force. I just returned it to TSC and the manager said she has never seen that and offered to get another. I asked what if it happens again and she said she would take it back again. That is great customer service but I do not want to take the chance again. Either they are junk or the steel was defective. Either way I am looking for a good used one or maybe an ETA new one.
I've figured out that if the top link connection is like this one, it built by Tarter.
If it's like mine, it's built by Behlen in Columbus, Nebraska.
I think the Behlen is a bit sturdier?
/ County Line(TSC) Landscape rake #46
465807d1461359909-county-line-tsc-landscape-rake-imageuploadedbytractorbynet1461359874-933029-jpg
that looks just like my back blade but with a rake on it.
/ County Line(TSC) Landscape rake #47
I own the 1 in the 2nd photo & it has a Tarter label on it. Seems Tarter has a few different designs of rakes. There is definitely a difference in durability. I purchased mine from Southern States & it is a beast.
/ County Line(TSC) Landscape rake #50
Another poster pointed out this top-link option to get the float function on 3pt implements.
Hydraulink
I haven't tried it.
I already have a hydraulic top link. I think I can take about 8" long piece of square tubing, drill holes in one end got the top link pin on the rake. Then cut out about 3" of top and bottom sides of tube to end up with two ears on sides with hole for pin on the top link cylinder.
/ County Line(TSC) Landscape rake #51
It isn't a hydraulic top link. It's a top link that uses both pneumatic and hydraulic pressure to give you a self-adjusting link that can float or be rigid like a screw top top-link.
Website: HydrauLink™ - A self-contained hydraulic top link
/ County Line(TSC) Landscape rake #52
Website: HydrauLink - A self-contained hydraulic top link
I understand what the Hydraulink is, I just don't need to spend $130 when I can get similar result with $2 worth of Sq. tubing and a little machining labor.
Thanks for the link though.
/ County Line(TSC) Landscape rake #53
I hope you post pictures of your solution when you get it made.
/ County Line(TSC) Landscape rake #54
Yep, just need to find a short piece of 2 1/2", 1/4" wall sq. tube.
Kubota M125X (A60462)
Blue Diamond 103709 (A53317)
Blue Diamond...
Cat CB24B (A60462)
Cat CB24B (A60462)
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2016 Chevrolet...
