core aerator
/ core aerator #1
cowpie1
Kellogg, IA
NH TC33DA
Could anyone point me in the direction of a good manufacturer of a core aerator I could pull with my JD 320?
I am not sure best length but assume 36" probably the max. Any input from y'all would be appreciated!
Cliff
/ core aerator #2
I have used an AGRIFAB areator for more than 10 years on several commercial and large residential properties. It is about 36inches or so. Great for any garden tractor. Only repair I have had was a plastic bushing this last fall. Easy $10.00 fix after 10 years of reliable service!!!!!!!!!!
These should be avaliable at any lawn\garden center.
John
/ core aerator #7
The residential model was designed for the home owner that did not have anything more than a lawn tractor, so it was not designed to fit a 3pt hitch. It weighs in at only 135 lbs, and has less tines per wheel. If you are using a 3pt hitch then that means you have acerage to justify a tractor, and a 30" aerator will take forever on large acreages.
Jason
/ core aerator
Thanx for all the replies!! Will do my research now and make a decision! Looks like some good stuff out there. My yard is in need of aeration on a regular basis.
/ core aerator #11
turfaire said:
If I can help answer any questions regarding our products, feel free to ask. Besure to ask me direct questions if you ask on the forum, or you can PM me.
Jason B Bour
Bishop Enterprises Inc Bell Buckle, TN
Nice equipment at a decent price. If I ever get in the market for an Airator, I'll definitely keep you folks in mind.
/ core aerator #12
Jason
In that case let me ask this, do you offer any models which will fit a Cat. 0 three point? I am looking for the convenience of being able to raise and lower the unit with the 3ph, but I don't have the need for a model in the "acres per hour" class. JD makes a 3ph kit for their overpriced Brinly copy, I figured you might do the same.
/ core aerator #13
JohnSinVA said:
Jeff which tractor are you pulling it with?
Sorry I'm a little late in replying. The thread got some age to it, and I overlooked it for a few days.
I used my 4410 the first time I used my Turfco. I think before Spring I'll have a three point on my 455. The 4410 was just a little too big for some of the tight spots in my yard. I got it done, but with lots of turning and backing -- with bar tires on my yard. I am pretty sure the 455 (22 HP) can handle it.
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2009 Dodge Charger Sedan (A64194)
2009 Dodge Charger...
