Coolant temperature?
/ Coolant temperature? #1
BlueLS
Maine
2013 LS G3033H
Anyone know what the operating temperature of the coolant ought to be in a '13 G3033H?
/ Coolant temperature? #2
Pretty much any working engine should get up to at least 170 and stay around +- 200 degrees. Dont trust your factory gauges to be 100% reliable
/ Coolant temperature? #3
I don't have an LS, but my Kubota L4060 has what I believe to be a 180 deg f thermostat, so the coolant in the block would be regulated as in the following clip from the WSM :
I would imagine if you really want to know what your thermostat is you could either call the dealer or remove it and run the above test.
/ Coolant temperature? #4
Currently most engine thermostats operate around 180F to 190F,
some of the Tier 4 will run 210F t stats.
/ Coolant temperature? #5
It opens at 169 +/-2.7°F and is fully open at 194°F.
Mine has the same thermostat and normally runs around 176°F.
LOOK! (A65640)
LOOK! (A65640)
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
8ft. x 4ft. Lighted Sign (A65640)
8ft. x 4ft...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 FREIGHTLINER...
