Coolant temperature?
/ Coolant temperature? #1
BlueLS
Maine
2013 LS G3033H
Anyone know what the operating temperature of the coolant ought to be in a '13 G3033H?
/ Coolant temperature? #2
Pretty much any working engine should get up to at least 170 and stay around +- 200 degrees. Dont trust your factory gauges to be 100% reliable
/ Coolant temperature? #3
I don't have an LS, but my Kubota L4060 has what I believe to be a 180 deg f thermostat, so the coolant in the block would be regulated as in the following clip from the WSM :
I would imagine if you really want to know what your thermostat is you could either call the dealer or remove it and run the above test.
/ Coolant temperature? #4
Currently most engine thermostats operate around 180F to 190F,
some of the Tier 4 will run 210F t stats.
/ Coolant temperature? #5
It opens at 169 +/-2.7°F and is fully open at 194°F.
Mine has the same thermostat and normally runs around 176°F.
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
2T Chain Lever Hoist (A66408)
2T Chain Lever...
2022 EZ-GO ELITE...
2026 SDlanch SDLE20 (A64127)
2026 SDlanch...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
