Control unit leak hydraulic
/ Control unit leak hydraulic #1
avoboy
kubota g1800
i have this leak from the top of this unit the rusty looking bolt/plug I put a bit of jb weld on the top but that didnt fix it I cant remove the top section with the 3 nuts as one goes round and round and wont undo Any ideas?
/ Control unit leak hydraulic #2
Those 3 nuts should be on through bolts that run the full width of the stacks.
The plugs may need a sealing ring or o-ring.
Now i know its a plug One of the nuts turns with the bolt wont undo wont tighten Not sure of my next move can the plug be removed from the outside?
/ Control unit leak hydraulic #6
The "plug" should unscrew from the block. Most of the time the through bolts have nuts on both ends. If you loosen a through bolt you can blow out the o-rings that seal between the sections.
cheers mate I wondered if there was a nut on the bottom and then it was pouring
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
