Control unit leak hydraulic
/ Control unit leak hydraulic #1
avoboy
kubota g1800
i have this leak from the top of this unit the rusty looking bolt/plug I put a bit of jb weld on the top but that didnt fix it I cant remove the top section with the 3 nuts as one goes round and round and wont undo Any ideas?
/ Control unit leak hydraulic #2
Those 3 nuts should be on through bolts that run the full width of the stacks.
The plugs may need a sealing ring or o-ring.
Now i know its a plug One of the nuts turns with the bolt wont undo wont tighten Not sure of my next move can the plug be removed from the outside?
/ Control unit leak hydraulic #6
The "plug" should unscrew from the block. Most of the time the through bolts have nuts on both ends. If you loosen a through bolt you can blow out the o-rings that seal between the sections.
cheers mate I wondered if there was a nut on the bottom and then it was pouring
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2017 Mack Semi (A64047)
2017 Mack Semi...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICE MAKER (A64281)
WHIRLPOOL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
