Control unit leak hydraulic
/ Control unit leak hydraulic #1
avoboy
kubota g1800
i have this leak from the top of this unit the rusty looking bolt/plug I put a bit of jb weld on the top but that didnt fix it I cant remove the top section with the 3 nuts as one goes round and round and wont undo Any ideas?
/ Control unit leak hydraulic #2
Those 3 nuts should be on through bolts that run the full width of the stacks.
The plugs may need a sealing ring or o-ring.
Now i know its a plug One of the nuts turns with the bolt wont undo wont tighten Not sure of my next move can the plug be removed from the outside?
/ Control unit leak hydraulic #6
The "plug" should unscrew from the block. Most of the time the through bolts have nuts on both ends. If you loosen a through bolt you can blow out the o-rings that seal between the sections.
cheers mate I wondered if there was a nut on the bottom and then it was pouring
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A65643)
2006 W-W TRAILER...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
