Construction/equipment intercom recommendations?
   / Construction/equipment intercom recommendations? #1
Dadnatron
Veteran Member
Versailles, KY
JD 5100e with FEL
I find myself needing to coordinate with either ground workers or other equipment operators more and more. Phone isn’t an option.
What are your recommendations for a good reasonable quality two-way radio setup that can be expanded upon. I’d like it to be used with a headset and hands free would be optimal. Something comfortable, behind the neck rather than over head (or at least that option) and audible while in a tractor, excavator, skid steer as well as out on the ground.
Not looking to break the bank, but absolutely looking for reliability and ease of use. I’d rather pay a little more and cuss a little less.
Right now, just need for 2 people, but I’d like to be able to add, as I know I’ll need at least 4 within a year or so.
Also, “must haves” and “avoids” as far as options and qualities would be appreciated.
   / Construction/equipment intercom recommendations? #2
Sadly its no more but years ago most of my contractors had Nextel push to talk phones. Worked great for us.
   / Construction/equipment intercom recommendations? #3
This thread is extremely informative and will answer your questions:
   / Construction/equipment intercom recommendations? #4
Midland is a popular brand of two way radios used by farmers for communication between vehicles and have some decent range depending on model and features
Not what costs are though
   / Construction/equipment intercom recommendations? #5
If the ground-man is the guy with the shovel, I don't think he will be receptive to anything he has to wear on his head. There is a constant war with headgear and sweat. Something with a belt clip and high volume would best.
Cheap walkie-talkies would be worth a try. If one gets lost or broken, they're cheap, buy another.
   / Construction/equipment intercom recommendations? #6
Feeding off bigtillers reply; what about radios like LEO's wear, radio on belt, with wired mic and speaker combo that clips on shirt lapel?
I'm certainly not opposed to something other than a headset. I was thinking more 'hands free' being the point, and I don't want to have issues. However, it might be that interaction doesn't require it. I know when I'm in an excavator, skid steer, or tractor, I'm not hearing much and can say even less, unless I power down. My goal was to limit the 'slow down' to say 'this or that'.
Most of it would be machine to machine. But machine to ground is a definite.
   / Construction/equipment intercom recommendations? #8
I used to be a motorcycle referee for bicycle road races. Moto refs use FRS radios and headsets inside the helmet. Most used Baofeng UV-5s. A motorcycle helmet at speed is a fairly noisy environment due to engine and wind noise but it seemed to work ok most of the time. Sometimes in hilly areas the range was limited to a mile or so.
Maybe instead of a headset in a helmet you could use an over the ear type ear speaker with a mic. I don't know how those do with noise.
   / Construction/equipment intercom recommendations? #9
Maybe try communication devices for arborist workers.
2021 KUBOTA RTVX1100C UTV (A60430)
2021 KUBOTA...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
207273 (A52708)
207273 (A52708)
