Confused... Adding a 2nd Rear line ck27....
/ Confused... Adding a 2nd Rear line ck27.... #1
Jc8
North Bay, ON
2012 CK27h
I've looked and searched but I must not be using correct search words.....
Anyways, how much trouble is it to put another hydro line at rear of tractor?
Buying a snowblower that has hydro rotation and hydro chute. I only have one set?
Is this something a backyard mechanic can install?
Part# if anyone knows would be great then I can look at drawings!
Thanks!
/ Confused... Adding a 2nd Rear line ck27.... #2
/ Confused... Adding a 2nd Rear line ck27.... #3
Kioti offers both a first and second rear remote kit. See the link below for when I installed mine (Bobcat and Kioti are identical in this area) I listed parts numbers. I had the Bobcat dealer do the install as I do not have good wrenching skills. They did the first a year earlier, but I need the float the Kioti valve has the Bobcat one does not. Also look in the Kioti parts manual online and you will find the kit.
Third page has the part numbers
http://www.tractorbynet.com/forums/bobcat-tractors/327499-float-action-rear-remotes-3.html
And if you ever want to run hoses to the front
http://www.tractorbynet.com/forums/...t235-front-hydraulics-install.html?highlight=
Hope this helps
/ Confused... Adding a 2nd Rear line ck27.... #4
I installed mine on a Ck20 this past fall - bit smaller version of your tractor. Not especially difficult at all. The instructions said remove the rear wheel, I didn't and it wasn't needed. (Other's have said the same thing.) Biggest pain is actually getting the hardlines in place. Otherwise it's a straight forward job. If you've spent some time with a wrench in your hand you should have no problem.
E.
/ Confused... Adding a 2nd Rear line ck27.... #5
Error
Go to the parts book and enter Kioti tractors, then in the next block Tractors, then the next block CK27 then CK27H then OPTIONS. Under options there are two remote hydraulic valve groups the single and the second. Hope this helps
Ok cool....that's awesome....now some questions...
1. I have a set of rear hydraulic remotes....do I need to buy the set that's "2" or can I add 1 set to what I have.
2. I am handy with wrenches, not a problem it's the ordering of correct parts...I seem to always order the wrong thing (partially) and I hate paying a restocking fee so I just keep my "mistakes"
Powerscol....is the part #322027 the kit # for the second line and it's only ~400$.... I must be missing something here...there parts on the diagram when you follow the path you gave me that are way, way more?
Thanks, I' m buying a snowblower with 2 circuits and would like to figure this out on the cheap.
/ Confused... Adding a 2nd Rear line ck27.... #8
I originally added just one remote to my CK30hst. About a year later, I added the second. You remove the first remote, remove the short attaching studs from the tractor, install longer attaching studs, slide the second remote on these longer studs, then the first remote, and tighten with nuts on the studs. As mentioned, the hard lines are a pita to get lined up. Get the lines in their locations, loosely attach to remotes, attach QDs to mounting bracket, loosely attach the lines to the QDs, barely snug up each, mount the bracket to the tractor, and then finish tightening. Sorry, it's been about 8 years ago and I don't have the parts order sheet. I don't know where you are getting your parts from but if you call Michigan Iron and Equipment and talk to Robert, their parts guy, he would know exactly what is needed.
/ Confused... Adding a 2nd Rear line ck27.... #9
That is the part number for the second remote kit that goes outside of the first on the install on my CT 235 which is the same as the CK35 or CK35H (same family as your CK27H, unless they changed the part number. In shopping around the best price by far was from Jacobsen, A Palm Springs Kioti dealer. 760-200-0098. Ask for Juan in parts. Not to be negative but I had issues with many other Kioti dealers as they did not understand that Kioti parts fit Bobcat. Even the Colorado dealers were not helpful or were full price. Shop around. If I need something else I will be calling Juan as he seemed to want to get me the correct part at the right price. Maybe someday Kioti and Bobcat will figure out that developing a cross reference between parts could mean $$$$ to them. Until then we need to dig a bit.
On edit, even Kioti did not know the parts would fit. I called their customer service number and was told No it would not work. Once the install was done I sent a nice email it did work, but got no response...seems strange to me, but whom knows??????
That is what is great about the TBN family - folks share.
Good luck and being confused is a good thing..........at my age confusion is normal :eek::D:thumbsup:
Thanks! Just what I needed...I'm in northern Ontario so I'm kind of stuck staying up here! ( Canadian dollar is taking a beating too!)
Glad I asked as I would have thought you need to order a set of 2 and remove the original!
/ Confused... Adding a 2nd Rear line ck27.... #11
If you have a good dealer you trust, get with them to confirm and talk to the mechanic on the install - there is a trick to it and you do not need to remove the tire, however getting the seat out can be a bear. My mechanic indicated attaching the new rear mount first helped, but leave everything loose, Then you thread the tubing to the mount before connecting up to the valve. He again said keep everything loose then once lined up tighten is sequence.
I would have done it myself, but I could not budge what he had installed before, so he gave me a good price to put the second one on. He too was surprised the Kioti parts matched up perfectly. This gave him and alternate source for parts.
/ Confused... Adding a 2nd Rear line ck27.... #12
When I was finding my kit for the Ck20 here in Ontario I used my dealer (Maxwell Farms) No where near you of course but they were on the ball. I second asking your dealer. I'd say I have one remote installed already and I want the kit to install the second remote. If you're not confident you're getting across what you're looking for then take the parts guy/gal out to a tractor and point to the second remotes/lever etc. They should find the kit in their book. As mentioned above it comes as a kit in a box with everything you'll need.
Not sure if others already posted these links - I know some one mentioned calling/looking at Michigan Iron website - I used it myself for my tractor. As an example here's 2 options for your tractor:
Error
and:
Error
The second link is the kit for both remotes, the first is for one set of remotes.
E.
/ Confused... Adding a 2nd Rear line ck27.... #13
Error
and:
Error
E.
*EDIT* Note the links say error but they link properly when clicked on.
