Confused... Adding a 2nd Rear line ck27....
   / Confused... Adding a 2nd Rear line ck27.... #11
If you have a good dealer you trust, get with them to confirm and talk to the mechanic on the install - there is a trick to it and you do not need to remove the tire, however getting the seat out can be a bear. My mechanic indicated attaching the new rear mount first helped, but leave everything loose, Then you thread the tubing to the mount before connecting up to the valve. He again said keep everything loose then once lined up tighten is sequence.
I would have done it myself, but I could not budge what he had installed before, so he gave me a good price to put the second one on. He too was surprised the Kioti parts matched up perfectly. This gave him and alternate source for parts.
   / Confused... Adding a 2nd Rear line ck27.... #12
When I was finding my kit for the Ck20 here in Ontario I used my dealer (Maxwell Farms) No where near you of course but they were on the ball. I second asking your dealer. I'd say I have one remote installed already and I want the kit to install the second remote. If you're not confident you're getting across what you're looking for then take the parts guy/gal out to a tractor and point to the second remotes/lever etc. They should find the kit in their book. As mentioned above it comes as a kit in a box with everything you'll need.
Not sure if others already posted these links - I know some one mentioned calling/looking at Michigan Iron website - I used it myself for my tractor. As an example here's 2 options for your tractor:
Error
and:
Error
The second link is the kit for both remotes, the first is for one set of remotes.
E.
   / Confused... Adding a 2nd Rear line ck27.... #13
Error
and:
Error
E.
*EDIT* Note the links say error but they link properly when clicked on.
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
2006 Ford E-350 Enclosed Knapheide Service Van (A55852)
2006 Ford E-350...
(APPROX.128) UNUSED 1X6 TONGUE & GROOVE (A57192)
(APPROX.128)...
403 (A52706)
403 (A52706)
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
