Concrete Posts.
   / Concrete Posts.
Beppinton... no I don't but I was thinking of running an old very course file across the edge... my good neighbour that showed up after suggested a grinder...
The next pour I will get fancy with some curved(gothic) tops and chamfered edges... will use wood pieces to add to the mould.
egon - that's what the tractor is for. But yes... shovelling and lifting cement bags and all that stuff is laborious but good for the heart too!
We estimated the costs to be just over $6 per post.
2.5 bags of cements at $12 per bag = $30
Stone/sand mix about $6
Pex Pipe: $2.00
Metal Reinforcement: $9
Total: $47 / 8 posts(6 - 4"x4" + 2 - 4"x5") = $5.87 + tax!!!!!!
I've seen them on line for $97.44 per post and up.
PC4600 for 4" x 6" Post
Hopefully this will work.
   / Concrete Posts. #63
Pex Pipe: $2.00
That's great! I'm spending $5.97 + 6.25% tax = $6.34 for every 4"x4"x8' PT wood post, & we all know these aren't gonna last forever. And some of them curve after installation, too - You won't have that problem, either.
   / Concrete Posts. #64
the 2x6 that will be fastened to the post, is it going to be bolted thru the pvc pipe?? if not how will it be fastened to the post??
heehaw
   / Concrete Posts. #65
One suggestion on the steel you are putting in. For it not to rust it needs to be inside of the concrete at least 1", 2" is usually the min on rebar in slabs. If it is close to the surface it will eventually be exposed and then rust out inside the concrete.
May not be an issues down the road if you are just concerned about breakage during the molding process.
   / Concrete Posts. #66
You may want to consider a hole thru the post near the top (3 or 4" down) to use for setting the post. Run a cable thru the hole and have your FEL lift the post to set it in the post hole.
   / Concrete Posts.
heehaw,
Yes the pvc goes through the post. 2x6 will get bolt to post.
Whitnel,
Thanks. Will file away for future reference and use.
TRR,
Good point. I was hoping, naively, that we would just tip the post into the hole from the loader forks. The top hole for the 2x6 is 12' from the top. I could make a sling to go through hole and hook to forks or put a bar through and connect a sling to the bar ends.
We took the ends off the form yesterday... just to see. We are going to leave them a little while more to cook before removing. I also think more release liquid is needed. Also, we may have to look at the sand/aggregate mix. Could be a little more "finer" - I am using left over mix from a project last year. Recent observations, from friends who have seen posts in Europe and England, think a mixture of sand and river pebbles or pea gravel may be better.
   / Concrete Posts. #68
One other thing I though of. Are you vibrating the form at all when pouring. You might experience some honeycombing from trapped air if not. It could be as simple as hitting the form with a hammer during the pouring process.
   / Concrete Posts. #69
My thought was to build the form on a plywood sheet, but the plywood would not have a frame fastened underneath, just resting on one. When ready to remove the posts, the plywood could be lifted a bit in the center, forming a very mild arch and spreading the form boards away from the posts.
Bruce
   / Concrete Posts. #70
I helped make concrete posts about 20 years ago at a community centre, ours were 4x4" posts and if I remember they were about 10 feet tall.
we used to make 2 a day just before leaving, I think we had 6 moulds in total. we made them on a big flat table and were able to strip the mould without moving the post so they dried for at least a few days before moving them.
We put two runs of 1/2 inch rebar in each one and holes for the wire too but i dont remember how we did that now.
Next time I am home (likely next year now) I will have a look and see how they are doing, oh and they are on the beach or almost so pretty harsh conditions for the rebar..
If I were making posts again I would be using the single post per mould method as I remember very little trouble with it...
Oh and we used sand/gravel from the pit and just added our own cement, way cheaper than bags and make it as strong as you like...
Keep up the good work though
oh and edit, we just tapped the forms with a hammer for vibration, not the best method but it seemed to make good posts for us.
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2014 CATERPILLAR 242D WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
