Concrete estimate
/ Concrete estimate #41
I was wondering what happens with the rebar or wire when deep control cuts are made.
It won't hurt anything to cut the steel at the control joints, you want the concrete to crack there (control joints).
/ Concrete estimate #43
Since this thread is going good, I have question regarding cracks NOT inside an expansion joint. I had my concrete put down in 2011 and this year with the extremely cold winter the frost heave gave me a crack (in the smallest section, which is triangular) for my outside pad.
It is hairline NOW and I was thinking it should be filled with some thin liquid that would penetrate down into it. It has a top cure coat that was sprayed on the day of the pour but no other coating & is standard whitish concrete with fiber 6000 psi mix. The separation is flat 5.5" thick and width of crack is from nothing to maybe 20 thousands wide, depth unknown, length maybe 8 feet.
Suggestions as to what to fill it with. Also I have not filled the expansion joints but would think this year of doing that on the outside slab sections. They are typical and only 3 of them that form a triangle and a square pad across the front of the barn.
about best pic of the spot, it comes from the man door towards the spot I was standing taking the photo.
other pics and videos there if you click on above pick U can scroll thru the pour and what it looks like now, no pics of the crack (still on the phone tho.)
mark
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
2021 KUBOTA KX080-4 SUPER SERIES 2 EXCAVATOR (A65053)
2021 KUBOTA...
UNUSED FUTURE DHC-60" PALLET FORKS (A65055)
UNUSED FUTURE...
2016 JOHN DEER 5075M TRACTOR AND BUSH HOG (A66091)
2016 JOHN DEER...
2000 Hino (A64194)
2000 Hino (A64194)
