Compression Testing
/ Compression Testing #1
KH380CK
KC, MO
Case 380CK, Case 580CK
How do I test compression on an engine with bolt on CAV injectors? Every kit I see seems to thread into the cylinder head.
Is there an adapter or special tool for this type of cylinder head? Or can I take apart an injector and thread the compression tester onto it?
Engine is in a 1980 Case 380CK.
/ Compression Testing #2
Nice pic. Artistry in engineering!
Don't take your injectors apart!!!
Remove injectors and install adaptor. You may be able to hire them in US from NAPA or a diesel shop?
Snap-on has various types for approx $120. eg. Adaptor, Diesel Compression Gauge
Thank you!
/ Compression Testing #4
The issue might be pulling the injectors. They can be a bugger.
On this engine there is only a cold start assist located on the intake manifold.
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
