Compression Testing
/ Compression Testing #1
KH380CK
KC, MO
Case 380CK, Case 580CK
How do I test compression on an engine with bolt on CAV injectors? Every kit I see seems to thread into the cylinder head.
Is there an adapter or special tool for this type of cylinder head? Or can I take apart an injector and thread the compression tester onto it?
Engine is in a 1980 Case 380CK.
/ Compression Testing #2
Nice pic. Artistry in engineering!
Don't take your injectors apart!!!
Remove injectors and install adaptor. You may be able to hire them in US from NAPA or a diesel shop?
Snap-on has various types for approx $120. eg. Adaptor, Diesel Compression Gauge
Thank you!
/ Compression Testing #4
The issue might be pulling the injectors. They can be a bugger.
On this engine there is only a cold start assist located on the intake manifold.
16.5' Telescoping Ladder (A66408)
16.5' Telescoping...
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
Kenworth T6 (A63689)
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
