Compression Testing
/ Compression Testing #1
KH380CK
KC, MO
Case 380CK, Case 580CK
How do I test compression on an engine with bolt on CAV injectors? Every kit I see seems to thread into the cylinder head.
Is there an adapter or special tool for this type of cylinder head? Or can I take apart an injector and thread the compression tester onto it?
Engine is in a 1980 Case 380CK.
/ Compression Testing #2
Nice pic. Artistry in engineering!
Don't take your injectors apart!!!
Remove injectors and install adaptor. You may be able to hire them in US from NAPA or a diesel shop?
Snap-on has various types for approx $120. eg. Adaptor, Diesel Compression Gauge
Thank you!
/ Compression Testing #4
The issue might be pulling the injectors. They can be a bugger.
On this engine there is only a cold start assist located on the intake manifold.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
2012 EXAOS 130BBL (A65643)
2012 EXAOS 130BBL...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
