Componentry for foam marker system?
/ Componentry for foam marker system? #1
7864
I`ve been looking at foam marker systems for my self made 3 point boom sprayer. Can a person buy the components somewhere, or are we stuck buying a fairly pricey system from one of the many manufacturers.? The foam nozzles and hosing look a lot alike across the brands. The most economicalredi-made system I have found so far is from Salvaroni @ $290 from agri-supply.Thoughts on this idea??
/ Componentry for foam marker system? #2
A couple of people here have made their own out of small 12v air compressors and such. Do a search on foam markers or diy foam marker.
/ Componentry for foam marker system? #3
Do a search for "Foam Marker" and select forums started be a member and enter PINERIDGE for the member name. He has a very detailed post documenting the entire building and testing to complete a foam marker.
Speaking about PINERIDGE , I noticed that it has been a while since I have seen any posts from Mike. Hope everything is OK.
Dan
/ Componentry for foam marker system? #5
Why could one not make something to hold a can of ground marker paint such as the utilities use to mark underground cable?
/ Componentry for foam marker system? #6
Wouldn't that get kind of expensive at $5.00 or so a can? And who would want red, orange, yellow, blue or white stripes on thier lawn?
/ Componentry for foam marker system? #7
I'm thinking of an intermittent system. You don't have to continuously mark. A mark every 50 ft (or more) would probably be plenty.
The marks disappear fairly quickly.
/ Componentry for foam marker system? #8
Isn't there a system that rolls out toilet paper?:D Maybe that's just for those agricultural spray planes for big farm fields.
Thanks for the link kenny. I was involved in that thread last summer. Its where I got some ideas and help from Pineridge. Is he still around here on this sight? I would like to build my foam system to be like the store bought ones. I can tell that the components are alike in many cases across the brands, but who is the original supplier to these companies? I`ve searched but can`t find the original source for the verticle drop nozzles (which make the foam at the ends of the boom) or the tank/compressor setup.
/ Componentry for foam marker system? #10
7864 said:
... Is he still around here on this sight? ...
I believe he and the misses are working almost 24/7 at their newly opened store.
/ Componentry for foam marker system? #11
There is a company out there that makes a foam marker system for walk behind fertilizer spreaders. I have 3 of them. They were relatively cheap at $150. As far as components go, it has a low volume air pump, switch, battery, plastic jar, plastic hoses, and a foam nozzle. Get the 12v model, and you can use the smallest motorcycle battery to run it and save on throwaway batteries. I believe the name of the company is Richway or some variation of that. You may want to try this question on Lawnsite or lawncare and landscaping Forums.:D :D :D
/ Componentry for foam marker system? #12
Plans are available from Australia,(aprox $27 Aust) send private email for more details.
Regards,
R W
2002 EZGO Electric Cart (A64557)
2002 EZGO Electric...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
