Compact telehandler
/ Compact telehandler #121
Saw one it front of the Conroe branch of Bobcat of Houston this morning. I had the urge to stop and check it out, but just went home and crawled into bed. But one day I'll check one out.
hugs, Brandi
/ Compact telehandler #122
Try it, you will like it! especially if you have never driven a 4 wheel steer machine.
/ Compact telehandler #124
Got to use the 6' forks:
Forking a 6' pallet of rubber stall mats:
Will put 6 mats in the horse stall:
The dog likes them! :thumbsup:
/ Compact telehandler #125
Are you going to bid on it?
Since the auction link will not work sometime in the future, here is a snip for future info seekers so they know what it was:
And some downloaded pictures of the V417 to be auctioned:
View attachment 524633 View attachment 524634 View attachment 524635 View attachment 524636
And here is a snip of what it sold for:
/ Compact telehandler #128
/ Compact telehandler #129
This mostly dead tree was on the back of the dam last month:
Put the grapple against the trunk, got out and took the picture:
Reached in and extended the boom:
Picked it up and shook the dirt from the roots:
If you can just push over and then pick up by the roots, do you really need a tree puller? I would think it might be faster, because you could pop out several trees then stack them for burning without having to switch implements.
/ Compact telehandler #130
If you Google wheel loader with telescopic boom, you will see several. Having owned a large telehandler and missing the reach, this in my opinion might be the ideal solution. Lots of digging power, unsurpassed visibility, and a clear view to your forks.
/ Compact telehandler #131
The tree puller is faster on live cedar trees that are less than 6 inches diameter. Just pull and shake the dirt off of the roots. :thumbsup:
/ Compact telehandler #132
Good to hear. Now I'm thinking about foregoing a brush mower for now. Still have one for my old tractor, and if I can just pull out the heavier stuff that may be better.
New question: You have quite a few implements. If you had to narrow it down to 1,2 or 3, what are your most used / important implements?
Thanks!
/ Compact telehandler #133
I couldn't narrow it down to just 3. :eek:
But the 3 most used are:
If my wife hadn't bought the Toolcat to help with mowing, I would also keep the 7' brush hog:
/ Compact telehandler #134
Who makes that grapple? I can't seem to find the thread where you said before. You've called it the gorilla grapple, but there are two different manufactures that I've found calling theirs that...
/ Compact telehandler #135
That one is the Loflin Monster Grapple:
The little one is the Gorilla Grapple:
/ Compact telehandler #136
Here is a project with the stump bucket from 2016 that I never posted. The county brought out an excavator to remove the silt at the bridge barely visible in the background. They brought it over on our side of the fence and scooped out the area where the V417 is sitting:
It wasn't low enough to the west so I trenched on it over to the tree on the old creek bank:
This is what it looked like later:
Went back with the bucket and dug on past the tree:
Guess I should go back down there and see if it is silted in again. :thumbsup:
/ Compact telehandler #137
:drool:Awesome pictures of a true workhorse in action removed for brevity....:)
Now I'm jealous of both your machine and the ease at which you can dig there- I didn't see a single rock or boulder there, and in my neck of the woods, if you put a shovel or loader bucket into the ground, you run about a 50/50 chance that there's something there obstructing your progress and big enough to require remedial excavation to get it out of your way.
/ Compact telehandler #138
Oh we have some rocks here, just none down there where I dug the trench. :)
Some end up on the rock pile: :thumbsup:
/ Compact telehandler #139
But you also have the tool to move them when necessary- I gave our little B2320 a [hopefully temporary] BIG smiley face moving 1 large rock in particular while digging our new drainage channels.
I have to get home and then I can upload my rock pictures, I'll include our smiley face tractor, if you don't mind my thread jumping/poaching for a post- I don't think it's worth starting a new thread- unless you think people will contribute to a "How I screwed up [my bucket]" thread...
Thanks for the prompt reply- The rocks just laying there didn't seem like much to write about, but I know you better than to believe that.
...And those same rocks look a dang site bigger with your compact T-H there for comparison...
/ Compact telehandler #140
Yep, post them here, I'd like to see your rock pictures and smiling bucket.
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2022 FAE UML/SSL-150 Sonic Mulch Head (A63116)
2022 FAE...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
