Bentrim
- Joined
- Apr 22, 2020
- Messages
- 373
- Location
- York County, Pennsylvania
- Tractor
- Massey Ferguson 245, Massey Ferguson 14 Allis Chalmers G
Direct injection is not necessarily common rail. Direct injection injects the fuel into the top of the piston into a specially designed combustion chamber designed into the piston. They are usually easier to start and noisier than indirect injection as the fuel is burned "on top or in" the piston. Indirect injection uses a "pre combustion chamber" where some or all of the fuel is burned in this chamber and the gases exit the chamber and force the piston down. Some called the power cells, pre combustion chambers, Oliver used the Lanovan system Minneapolis Moline called them Dyna Cells. These systems were quieter and easier on parts and usually harder to start when cold. Some are accessible externally and some were built in the heads. An example of an IDI is the GM 6.2 and 6.5 Indirect and direct usually use an externally mounted injection pump.another aspect of direct injection (common rail) vs indirect injection injection (mechanical) is the location in the combustion chamber fuel is injected. Indirect injection is what the name implies, fuel is injected indirectly into the combustion chamber and is not as efficient as DI.
Also mechanical is what the name implies, a mechanical pump and an extra cam to operate the injectors. Both systems have pluses minuses and both can be costly to repair. You can put me in the column of turbo fan boy as well. Diesel engines do not like to breath on their own like a gasoline engine does.
Common rail has the fuel delivered at very high pressure to all injectors at the same time. It is fired when triggered by a computer. They cannot run without electronics.
The good points of Common rail is the computer control can cause multiple injections and amounts for one firing. This is why common rail has become popular. They use direct injection and with the computer controlling it they are quiet and can reduce emissions compared to the old mechanical pump systems. and due to the higher pressure they also are more efficient and start better when cold.
As for turbos I knew an old farmer who when he bought a new tractor put a turbo kit on it and turned back the fuel settings. He wanted the efficiency not the power.
