Common rail vs mechanical injection
/ Common rail vs mechanical injection #101
another aspect of direct injection (common rail) vs indirect injection injection (mechanical) is the location in the combustion chamber fuel is injected. Indirect injection is what the name implies, fuel is injected indirectly into the combustion chamber and is not as efficient as DI.
Also mechanical is what the name implies, a mechanical pump and an extra cam to operate the injectors. Both systems have pluses minuses and both can be costly to repair. You can put me in the column of turbo fan boy as well. Diesel engines do not like to breath on their own like a gasoline engine does.
Direct injection is not necessarily common rail. Direct injection injects the fuel into the top of the piston into a specially designed combustion chamber designed into the piston. They are usually easier to start and noisier than indirect injection as the fuel is burned "on top or in" the piston. Indirect injection uses a "pre combustion chamber" where some or all of the fuel is burned in this chamber and the gases exit the chamber and force the piston down. Some called the power cells, pre combustion chambers, Oliver used the Lanovan system Minneapolis Moline called them Dyna Cells. These systems were quieter and easier on parts and usually harder to start when cold. Some are accessible externally and some were built in the heads. An example of an IDI is the GM 6.2 and 6.5 Indirect and direct usually use an externally mounted injection pump.
Common rail has the fuel delivered at very high pressure to all injectors at the same time. It is fired when triggered by a computer. They cannot run without electronics.
The good points of Common rail is the computer control can cause multiple injections and amounts for one firing. This is why common rail has become popular. They use direct injection and with the computer controlling it they are quiet and can reduce emissions compared to the old mechanical pump systems. and due to the higher pressure they also are more efficient and start better when cold.
As for turbos I knew an old farmer who when he bought a new tractor put a turbo kit on it and turned back the fuel settings. He wanted the efficiency not the power.
/ Common rail vs mechanical injection #102
I'm sure some do but that certainly isn't a place to try and save a few dollars. I added an additional separator on my powerstroke for an additional safeguard.
/ Common rail vs mechanical injection #103
common rail injection without all the other emission trash would be great !
/ Common rail vs mechanical injection #104
But how many owners of CR fuel systems base their fuel filter choices on price?
A bunch of them since they refuse to comprehend OEM filters are MUCH cheaper than the parts they are protecting. Or they don't know there is a difference.
I will say it doesn't help with a lot of the knock-offs and the way places like amz push the trash sets.
The person that doesn't know any better gets on amz for both fuel filters for a '13 2500 6.7 Dodge. He sees 1 or 2 sets for $115. Then the amz choice (garbage) JKL or some other no name brand for $39.
/ Common rail vs mechanical injection #105
I was buying the Fuelly brand of Amazon for a bit until I went with a FASS and switched to the large Cat filters. With the stock fuel filter setup I was changing every 10,000 miles and with the FASS it says every 30,000 so after my first change at about 1000 to get rid of the junk left over from the sump install and the other tinkering that was necessary, I'm going to see if 30,000 is a good interval or if it needs to be less. The Fuelly had good reviews, looked exactly like the Cummins filter and came out just as nasty. The thing with the Chinese, a lot of times they will produce the exact same part for a fraction of the price under a different name because the name brand has all the engineering behind it, and the Chinese brand is run on the same line with the same parts, but only has manufacturing costs. I'm fully aware the cost of injectors and with 245k on what I'm assuming are the stock injectors, I want to make sure they are protected. I saw somewhere on Cummins literature the 6.7 Cummins is only rated to about 325k miles, but I'm assuming that's due to the EPA junk killing it off early.
/ Common rail vs mechanical injection #107
I've got to agree with that. OTOH, without the push to clean up the emissions I wonder if common rail would ever have been invented?
The is an amazing difference in the color of the air in big cities from what it was in the 60s through the 80s. Even the buildings are cleaner.
rScotty
/ Common rail vs mechanical injection #108
Before I joined TBN, I would have based my answer on my own experience with my customers when I had a mechanical shop, and said, "Very few; maybe none. The savings just isn't worth the gamble."
And I would have been way wrong. Apparently aftermarket filter use is common, in spite of there being no reasonable way to check their quality.
Over the past 15 years we get a couple of threads a year where someone has a problem caused by using after market filters to save money.
But I don't recall a single instance of problems caused by OEM filters. There probably have been some I missed, but not as many.
rScotty
/ Common rail vs mechanical injection #109
Officially, Cummins gives the 6.7L a B10 rating at 250k and a B50 rating at 350k. A B10 rating means that 10% of all 6.7L engines in operation will require major repairs or an overhaul at that mileage and a B50 means that 50% of all 6.7L in operation. Keep in mind that these engines go in a lot more than just pick-up truck too. The 6.7 Cummins is being used in more demanding applications than it’s competitors.
/ Common rail vs mechanical injection #110
Yeah, school busses, box trucks, etc. At 200k when I bought mine, it had a blown head gasket so I guess I'm following the ratings
/ Common rail vs mechanical injection #111
Ford uses the 6.7L Cummins and previously used the 5.9L and 8.3L in their F650 & F750 so does PACCAR (Peterbilt) called a “PX-8”.
Cummins 5.9L, 6.7L and 8.3L found in many AG tractors. AGCO called Cummins engines “AGCO power”.
You won’t find competitors used in all these applications
/ Common rail vs mechanical injection #112
Since the 6.7 replaced the 5.9 the list continues. Cranes, marine engine, generators, forklifts, backhoes, dozers...
/ Common rail vs mechanical injection #113
To put it another way, the 6.7 starts at -40C without being plugged in. No aids other than the grid heater. Not the best for it but it will do it.
Lets see anything from before 2000 pull that off, the list has almost no members.
The old mechanicals, might as well stay home in the cold. The new rigs are champs.
Even the new deere’s run like a tuner car, no waiting around the power is instant. It sucks they just finally got diesel figured out just as they start pushing the green agenda.
/ Common rail vs mechanical injection #115
My BS meter just blew up.
From Northern Alberta, ive tested it lots. 6.7 always starts. Not like the -10C plug in hybrid powerstrokes lol.
Here is a guy at -37C not even an issue. 6 in a row and built to tow!
/ Common rail vs mechanical injection #117
Well, if it's on the internet..............
Looks like you got schooled lol
I can tell by the sound of the cranking that engine oil is crazy cold.
/ Common rail vs mechanical injection #118
Yep. We were all forced to spend more money to buy them with thousands of dollars of extra low emissions DPFs and DEF systems get them down to very low emissions only to see them probably become extinct in cars, and maybe even trucks
/ Common rail vs mechanical injection #119
Every day is a school day. Crazy cold and -40 may or may not be the same thing.
I never thought I'd see -30F but we had it 4 days running in upstate NY circa 1994. The coldest I've experienced.
/ Common rail vs mechanical injection #120
Well the guy showed in the video it was -35…..
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
Dragline Bucket (A65640)
Dragline Bucket...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
