ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,727
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
By the time I get back to the shed and unhook the attachment, it had plenty of time to cool down.
yep The CX 105 has 3000 hrs, cummins has 135,000 miles, kubota has 1000 hrs. I better go ahead and have those turbos replaced before I run into failures !Dang!!!
Must be all the turbos on the farm are shot to heck, most of those turbo'ed diesels
have well over 6000 hours on them a few over 10,000 hours, they are getting a bit tired.
We idle down for the last few minutes and don't work them hard before shutting down,
but they sure as heck don't idle for half an hour.
My little V6 diesel RAM had 98,000 miles and several thousand hours on it when I traded her in
and it had no issues to speak of.
Turbo rebuild is 500+ plus all of the piping, so around 1k.
You're not buying new turbo piping if a turbocharger fails. Maybe a new v-band clamp but that's it.
But they aren't as fuel efficient as newer diesels without emissions.^^agree. It took diesel a bit longer to get "high-tech" but especially with pick-ups, they are much more efficient than a dozen years ago. Higher compression, higher boost, higher pump pressures, precision injectors, computer controlled, variable cam timing......the list goes on.
Turbos are killed faster when shutdown hot. Idle for half an hour so they cool down kills any savings.
Average turbo life is measured in 100s of hours before the bearings wear out.
Will never buy a turbo diesel again.
Good grief, If I had to do that, I’d still be doing my first cutting hay. LolTurbo rebuild is 500+ plus all of the piping, so around 1k.
Not the brightest bunch I will admit, seeing they turned into a holland and then kubota dealer.So you claim.
Yeah, who wants to own a Kubota?Not the brightest bunch I will admit, seeing they turned into a holland and then kubota dealer.
I have had lots of diesel motors, and never a turbo failure.Interesting that the "efficiency" myth continues after the whole dieselgate thing.
High pressure common rail is not any more efficient than mechanical. The injector nozzles determine the maximum flow and pattern.
However, the Teir 4 version if that tractor will seem more efficient as it utilizes a turbo. By under tuning and requiring the turbo to activate for full power there is a perception of fuel economy.... at a significant parts and maintenance costs when something fails.
So if you want to pay a few dollars less to refill the tank and a few hundreds more maintaining, that would be the version.
There has been very little advancement in diesel efficiency in the last 50 years other than a rotary diesel engine that was released a year or two ago (half size, same power density).
Nobody idles a diesel turbo for 30 minutes prior to shutting down. Less than 5 minutes is good. I’ve had several diesel turbo trucks and cars with hundreds of thousands of miles on them. Never a turbo failure.Turbo rebuild is 500+ plus all of the piping, so around 1k.
You better rethink that. Super chargers are virtually unavailable on tractors and vehicles. They absolutely can fail and they are parasitic on powerGlad all your diesel turbos are good. Have one turbo gas engine, will be the last turbo I own.
If I want extra I'll stick with a supercharger, at least they are reliable and perform on demand.
No betting required. Nebraska tractor tests have HP hours per gallon as a measure of efficiency. OECD tests have similar data.I'm betting a newer common rail tractor with DPF, doesn't get as good fuel economy as a non common rail DPF tractor.
My 5.9 Cummins gets about the same mpg as the newer 6.7 with dpf, but the 6.7 puts out more hp and torque.But they aren't as fuel efficient as newer diesels without emissions.
Cummins 5.9 without DPF gets better mileage than the newer 6.7 with DPF
Higher pressure allows higher pressure injectors which allow them to open and close faster. Higher pressure injectors have larger nozzles to deliver more fuel because they open and close faster. Hydraulic and electrical control allow injector solenoids to open and close faster and are also timeing advanced based on load - so they are variable timed injectors.I disagree. Common rail & computer control is much more efficient. If you study up on it you may change your mind.
Just think about how much advantage the higher injection pressures of the electronic injectors gives by providing better fuel vaporization. When the fuel burns better it allows for direct injection and less fuel used. That's the definition of efficiency.
That said, the only failures we've had with our diesel tractors and trucks in the last 25 years all involved common rail systems and electronics.
rScotty
I don't have standing to take a position on this (other than taking the opportunity to high jack an interesting thread).Then you are lucky, after the third one I sent it to the scrap yard.
compared to people I know with 6.7, I get about 5 more miles to the gallon with my 5.9My 5.9 Cummins gets about the same mpg as the newer 6.7 with dpf, but the 6.7 puts out more hp and torque.
I’m no authority on this topic, but it seems like most people I know who have had turbo issues were on gasser engines. I have never had issues with my diesel turbos. There are so many diesel turbo trucks in service that it seems like failures are uncommon on diesel motors.I don't have standing to take a position on this (other than taking the opportunity to high jack an interesting thread).
1. I know a lot of gear is turbo'd.
2. Other folks (me) have had crappy experience with different tech, turbo in this case. I had two late 80 early 90 cars ford, and Nisan both had turbo failures prior to 100k. Now I know they are probably poor representations of heavy equipment, and modern equipment, but, I do buy normally aspired equipment exclusively now, so the bias stuck right or wrong.
3. Those to get to thisAssuming you don't live at high altitude. What is the upside of a turbo in a fairly low use 60 or 70 horse tractor? I understand in applications that need more power with less displacement/weight, but I always wish my tractor was heavier not lighter. I am always grateful for easier access, simpler engines. But, I am old and still willing to learn, my next purchase will probably be a replacement skid (bobcat 773) and in addition to tires vs tracks, will be deciding normal aspire vs turbo.
In order, thanks in advance for the opinions, sorry if this is too much of a hi-jack, and it is a genuine question, not trying to fuel a fuss, honestly don't see the upside.
Best,
ed
