Common rail vs mechanical injection
/ Common rail vs mechanical injection #22
Dang!!!
Must be all the turbos on the farm are shot to heck, most of those turbo'ed diesels
have well over 6000 hours on them a few over 10,000 hours, they are getting a bit tired.
We idle down for the last few minutes and don't work them hard before shutting down,
but they sure as heck don't idle for half an hour.
My little V6 diesel RAM had 98,000 miles and several thousand hours on it when I traded her in
and it had no issues to speak of.
yep The CX 105 has 3000 hrs, cummins has 135,000 miles, kubota has 1000 hrs. I better go ahead and have those turbos replaced before I run into failures ! :sneaky: 🤣
/ Common rail vs mechanical injection #24
^^agree. It took diesel a bit longer to get "high-tech" but especially with pick-ups, they are much more efficient than a dozen years ago. Higher compression, higher boost, higher pump pressures, precision injectors, computer controlled, variable cam timing......the list goes on.
But they aren't as fuel efficient as newer diesels without emissions.
Cummins 5.9 without DPF gets better mileage than the newer 6.7 with DPF
I'm betting a newer common rail tractor with DPF, doesn't get as good fuel economy as a non common rail DPF tractor.
/ Common rail vs mechanical injection #25
Turbo rebuild is 500+ plus all of the piping, so around 1k.
Turbos are killed faster when shutdown hot. Idle for half an hour so they cool down kills any savings.
Average turbo life is measured in 100s of hours before the bearings wear out.
Will never buy a turbo diesel again.
That’s just BS. Turbos rarely give any trouble. I have a 5.9 Cummins with 12,000 hours, a 6.5 Detroit with over 100k miles, a 4 cylinder Deere motor with 4300 hours, and my mini x and skid steer are both turbos. I’m not the original owner of any of it so I can’t say for sure they’re all original turbos but I don’t have any evidence to support they’re not.
/ Common rail vs mechanical injection #26
Good grief, If I had to do that, I’d still be doing my first cutting hay. Lol
I ran 15 loads of soil today. Load with one tractor and let it idle maybe 1 minute and shut down. Run the MX-270 with an 8.3L Cummins (5,200 hours of heavy AG work) wide open for 5-10 minutes to spread. EGTs were down to 660 by the time I throttled down and drove back to pile….maybe 2-3 minutes.
I‘ve been running diesel trucks and tractors for 30 years and never replaced one turbo, ever! They’re tough as nails unless you don’t cool down and very forgiving if you forget, just turn engine back on a few minutes
/ Common rail vs mechanical injection #27
I've been working around or running turbo diesels nearly every day for decades.
Rarely see a turbo failure
/ Common rail vs mechanical injection #29
Glad all your diesel turbos are good. Have one turbo gas engine, will be the last turbo I own.
If I want extra I'll stick with a supercharger, at least they are reliable and perform on demand.
/ Common rail vs mechanical injection #31
Interesting that the "efficiency" myth continues after the whole dieselgate thing.
High pressure common rail is not any more efficient than mechanical. The injector nozzles determine the maximum flow and pattern.
However, the Teir 4 version if that tractor will seem more efficient as it utilizes a turbo. By under tuning and requiring the turbo to activate for full power there is a perception of fuel economy.... at a significant parts and maintenance costs when something fails.
So if you want to pay a few dollars less to refill the tank and a few hundreds more maintaining, that would be the version.
There has been very little advancement in diesel efficiency in the last 50 years other than a rotary diesel engine that was released a year or two ago (half size, same power density).
I have had lots of diesel motors, and never a turbo failure.
/ Common rail vs mechanical injection #32
Nobody idles a diesel turbo for 30 minutes prior to shutting down. Less than 5 minutes is good. I’ve had several diesel turbo trucks and cars with hundreds of thousands of miles on them. Never a turbo failure.
/ Common rail vs mechanical injection #33
You better rethink that. Super chargers are virtually unavailable on tractors and vehicles. They absolutely can fail and they are parasitic on power
/ Common rail vs mechanical injection #34
No betting required. Nebraska tractor tests have HP hours per gallon as a measure of efficiency. OECD tests have similar data.
/ Common rail vs mechanical injection #35
My 5.9 Cummins gets about the same mpg as the newer 6.7 with dpf, but the 6.7 puts out more hp and torque.
/ Common rail vs mechanical injection #36
I disagree. Common rail & computer control is much more efficient. If you study up on it you may change your mind.
Just think about how much advantage the higher injection pressures of the electronic injectors gives by providing better fuel vaporization. When the fuel burns better it allows for direct injection and less fuel used. That's the definition of efficiency.
That said, the only failures we've had with our diesel tractors and trucks in the last 25 years all involved common rail systems and electronics.
rScotty
/ Common rail vs mechanical injection #37
rScotty
Higher pressure allows higher pressure injectors which allow them to open and close faster. Higher pressure injectors have larger nozzles to deliver more fuel because they open and close faster. Hydraulic and electrical control allow injector solenoids to open and close faster and are also timeing advanced based on load - so they are variable timed injectors.
On pressurized rails with electronic or hydraulic injectors, the diesel compression is lowered from the normal 21->23:1 ratio incase there is a miss. Most mechanical diesels have been running at 21 through 23:1 for almost the last century. (Theoretical maximum is 25:1).
I never disagreed that higher volume injectors could be used more efficiently than lower volume. I only compared apples to apples - the same size injectors will yeild the same maximum power no matter what the source injector pump or fuel rail provides.
It is the same for two engine blocks with domed or dished pistons, the fuel supply does not mater as long as it is adequate for the application.
/ Common rail vs mechanical injection #38
Then you are lucky, after the third one I sent it to the scrap yard.
I don't have standing to take a position on this (other than taking the opportunity to high jack an interesting thread).
1. I know a lot of gear is turbo'd.
2. Other folks (me) have had crappy experience with different tech, turbo in this case. I had two late 80 early 90 cars ford, and Nisan both had turbo failures prior to 100k. Now I know they are probably poor representations of heavy equipment, and modern equipment, but, I do buy normally aspired equipment exclusively now, so the bias stuck right or wrong.
3. Those to get to this :) Assuming you don't live at high altitude. What is the upside of a turbo in a fairly low use 60 or 70 horse tractor? I understand in applications that need more power with less displacement/weight, but I always wish my tractor was heavier not lighter. I am always grateful for easier access, simpler engines. But, I am old and still willing to learn, my next purchase will probably be a replacement skid (bobcat 773) and in addition to tires vs tracks, will be deciding normal aspire vs turbo.
In order, thanks in advance for the opinions, sorry if this is too much of a hi-jack, and it is a genuine question, not trying to fuel a fuss, honestly don't see the upside.
Best,
ed
/ Common rail vs mechanical injection #39
compared to people I know with 6.7, I get about 5 more miles to the gallon with my 5.9
/ Common rail vs mechanical injection #40
Best,
ed
I’m no authority on this topic, but it seems like most people I know who have had turbo issues were on gasser engines. I have never had issues with my diesel turbos. There are so many diesel turbo trucks in service that it seems like failures are uncommon on diesel motors.
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
Volvo Water Truck, 3306 Cat Engine (A62679)
Volvo Water Truck...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
