Common rail vs mechanical injection
/ Common rail vs mechanical injection #41
I’m no authority on this topic, but it seems like most people I know who have had turbo issues were on gasser engines. I have never had issues with my diesel turbos. There are so many diesel turbo trucks in service that it seems like failures are uncommon on diesel motors.
As it seems on gas, it is only us unlucky few.
/ Common rail vs mechanical injection #42
Higher pressure allows higher pressure injectors which allow them to open and close faster. Higher pressure injectors have larger nozzles to deliver more fuel because they open and close faster. Hydraulic and electrical control allow injector solenoids to open and close faster and are also timeing advanced based on load - so they are variable timed injectors.
On pressurized rails with electronic or hydraulic injectors, the diesel compression is lowered from the normal 21->23:1 ratio incase there is a miss. Most mechanical diesels have been running at 21 through 23:1 for almost the last century. (Theoretical maximum is 25:1).
I never disagreed that higher volume injectors could be used more efficiently than lower volume. I only compared apples to apples - the same size injectors will yeild the same maximum power no matter what the source injector pump or fuel rail provides.
It is the same for two engine blocks with domed or dished pistons, the fuel supply does not mater as long as it is adequate for the application.
Believe what you want.
/ Common rail vs mechanical injection #43
Because they rev them higher, run them red hot, then shut them off.
/ Common rail vs mechanical injection #44
I have a couple NA diesels, and they have their place. On smaller equipment, like mowers, they are simpler and can be shut down immediately to hop on/off mower without turbo concerns. They are cheaper to maintain because less pipe/plumbing and clamps to fail.
However, exclusively buying non-turbo diesels because of a perception of failure is not realistic. The upside is way too great and honestly, there’s so few NA diesels produced over 50HP I can’t imagine there’s much available unless you want to buy 40 year old equipment
/ Common rail vs mechanical injection #45
Turbochargers rule. Not only are they more efficient, they make more power in the form of torque (which is what tractors want) at a much lower RPM.
Are they perfect? Heck no. Especially the VGT (variable geometry turbo) but I doubt you see many of those on tractors. But they've come a long, long way in the design of turbo engines. A long way.
When you own a turbo engine, you gotta keep in mind that if you're working it long and hard, you can't just immediately turn it off whenever you're in the mood. You gotta let it cool down (idle) for 2 to 5 minutes so the turbo doesn't cook the oil onto its bearings. Not good.
When you shut a turbo engine off, the turbo loses air flow, which is a big factor in its cooling. So it just sits there and bakes everything. Let it cool off
It's also important to run good oil in them. I run synthetic in my 6.7L Cummins. The wife's turbo'ed Edge gets the oil changed at the Dealer. Mostly because I'm too darn old to be crawling underneath a car with somewhere around zero ground clearance. Plus, all the tests done on Ford's oil came back really good. It's good oil.
Cheap oil will cake on the turbo's bearings over time and that's not a good thing.
/ Common rail vs mechanical injection #46
Even on naturally aspirated engines, I always let them cool down for a period if they've been worked hard immediately prior
I warm them up slowly, too. I don't go full throttle on a cold engine. Uncool
Just me
/ Common rail vs mechanical injection #47
another aspect of direct injection (common rail) vs indirect injection injection (mechanical) is the location in the combustion chamber fuel is injected. Indirect injection is what the name implies, fuel is injected indirectly into the combustion chamber and is not as efficient as DI.
Also mechanical is what the name implies, a mechanical pump and an extra cam to operate the injectors. Both systems have pluses minuses and both can be costly to repair. You can put me in the column of turbo fan boy as well. Diesel engines do not like to breath on their own like a gasoline engine does.
/ Common rail vs mechanical injection #48
A lot or older diesel engines that don't have common rail fuel injection systems are direct injection. My '91 JD 4255, '11 Kubota M7040,'81 Ford 6700 have mechanical inj pumps with direct injection
/ Common rail vs mechanical injection #49
Mechanical injectors fire from fuel pressure
/ Common rail vs mechanical injection #50
6.7 turbos are water cooled, so that helps.
Coking oil in bearings is pretty hard to do, but I understand the sentiment.
/ Common rail vs mechanical injection #51
Yea, it's been awhile since indirect injection with pencil stream injectors were common.
Spraying a steam of fuel across the cylinder into a power cell to ignite. My Oliver 1550
which even had a manifold heater so a person could feed the engine some warm air to help
it along.
/ Common rail vs mechanical injection #52
well, it's been awhile since I've looked at an idi. when I worked in the oilfield in the 70s I guess.
/ Common rail vs mechanical injection #53
My wife just picked up a BMW X-5 with a turbo straight six
you can barely, just barely hear the turbo (as opposed to my 8.3 Cummins which has amazing turbo whistle). ;)
Anyway, my wife doesn’t know a turbo from a transmission and she will pull in the garage and just shut it off. Not terrible, because we live on a long low speed lane before our driveway, but not the best when pulling in somewhere else ff highway then immediate shut down.
Noticed BMW has an pretty loud electric fan that runs after a hot shut down. Wondered if it was tied to an EGT probe for cooling the turbo?
Turbos can be air, oil and water cooled.
/ Common rail vs mechanical injection #54
The bearings on a turbo are oil cooled.
Whether that oil has additional cooling via water/air/other oil is application depending.
/ Common rail vs mechanical injection #55
I mean yeah of course, you cant run turbo bearings in water…..
Some turbos have water jackets to circulate coolant through them to aid cooling and lengthen service life.
Garrett GTX turbos are water cooled and there’s others.
Air cooling occurs by fan when still and fan/air blowing over them when in motion.
/ Common rail vs mechanical injection #56
Water jackets are generally to protect the surrounding equipment or people from the turbo heat, very common on marine engines. The only part that requires cooling is the bearing and that is done by a constant flow of oil. Water jackets or oil flow can’t cool the turbine in the exhaust steam.
Shutting off an engine when the compressor wheel is red hot causes the heat to transfer into the bearing and damage it but tractor or automotive size turbos only need a minute or two to cool sufficiently to prevent any damage. Remember these are now everywhere on every kind of idiot proof vehicle, most automotive turbos will survive regular hot shutdown as they’ve had to massively improve the bearing materials.
Even large turbos on engines in the 60-95 litre range only require 5 min max to cooldown.
To correct someone a ways back, turbo life is definitely not measured in hundreds of hours, it’s in tens of thousands. 30-40k hours on a turbo is common on an industrial engine though they are often included in a midlife overhaul around 15k hours.
/ Common rail vs mechanical injection #58
Yeah well water cooling improves turbo life in general, according to Holsett
/ Common rail vs mechanical injection #59
Wondering what the first use of a turbo was on a Compact Tractor? .... say, under 40 HP....?
The first one I can recall off the top of my head was the JD1050, and "tractor data" says that would be 1980.
Anyway, the JD1050 would have a 3 cylinder turboed Yanmar engine, and somehow that doesn't surprise me. An innovative company.
rScotty
/ Common rail vs mechanical injection #60
rScotty
If that wasn't the first it had to have been close. Yanmar had their own presence in North America about that time and had a CUT with a power shift transmission. 336 maybe? I wonder if that was turboed?
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
LOT LOCATIONS (A59914)
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
