Clearing forested land with a backhoe and tractor/grapple
   / Clearing forested land with a backhoe and tractor/grapple
I think where I may have screwed myself on this design is that I made it pretty heavy duty, so for me to lift it up and put it down, I'd say I'd probably be lifting a good couple hundred pounds. I think this would get pretty old really fast. If I was smart (no one ever accused me of that:laughing:) then I probably would have made it a little bit lighter and easier to handle.
   / Clearing forested land with a backhoe and tractor/grapple #32
While my son is often with me (15 years old and very strong) I agree with Rick getting of the tractor can be a good break.
My neighbor has a manual that must weigh 600-800 pounds on a big CAT track hoe that has to be moved by hand.
I have learned how to position the hoe so there is little pressure on the pin and then remove it then re-position the hoe so it in the next position that I want it then I move it a bit to get the pin back into the correct hole.
In our case it was a manual thumb for NO thumb because I have too many hoses to try and not rip off already. :) As noted I work in live burn piles sometimes bunching up the remaining wood. The more I use ours the better I learn how to position the hoe to reach my objective
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
