Clear Thousands of Acres of Brush in No Time With This One Weird Trick
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #11
Works so long as it is a solid internal shaft straight trimmer. The wound up wire shafts cannot take the shock and will fail real quick. I use a carbide tipped circular saw blade on mine quite a bit. Far as a severed foot, not happening, I have a guard on my Stihl FS straight shaft trimmer / brush cutter.
We have a thread where this was discussed. I'm skeptical of '"thousands of acres cut"
If you're referring to the post title, yes I would be very skeptical. I'm real suspicious of anything that includes the phrase '...with this one weird trick.' 😂
But if you had a thousand buddies with a thousand weed eaters and a thousand blades you could get thousands of acres cut in a weekend. Just make sure you own a small brewery to treat everyone to a couple of beers after its all done! 🙂
Seems like a severed foot waiting to happen.
You just need the correct PPE. I wore a loggers helmet for safety. I figured if I did amputate an appendage and had to call for help that the orange color would help the paramedics find me faster. ;)
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #14
I have had good luck with this type of blade. I found them to work better for me then the skill saw style blades.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #16
I have something similar, but it has chainsaw teeth on a circular metal disk. It does a good job, but is kind of scary. You definitely gotta take your time and be cautious.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #18
I modified my Ryobi weed trimmer to take standard circular saw blades. It just required me turning a register down a little. The straight shaft trimmer was made to accept special triangular blades. I turned the register down slightly smaller in the lathe. I use carbide tipped blades that I buy on sale. Even when the blades are dull from hitting rocks they still go through black berry and salmon berry canes and small diameter alders very fast. I cut through the berry canes just below ground level so I hit a lot of little rocks. But cutting through just below ground level means no stems sticking up.
Eric
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #19
On tall plants where the cut material interferes with the next “swipe”, cut a manageable length off, starting at the top. Yes, it might take 3 swings instead of one, but still quicker than wrestling a pile of tall cut stalks.
IMO. 2 cents.
   / Clear Thousands of Acres of Brush in No Time With This One Weird Trick #20
I used a Stihl “handlebar” machine with a blade that has chain saw teeth on it. It is named Forester. Does a good job and comes with a file for sharpening.
TANK MANIFOLD (A55745)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
