Cleaning Harness connections
/ Cleaning Harness connections #1
OrangeJbird
NW WI
3320 w/300cx FEL
What’s the acceptable service department method of cleaning this?
Wiring Harness 6430 Premium
Part Number AL201847
DescriptionWIRING HARNESS, ENGINE/4-CYL. 4VHPC
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.
/ Cleaning Harness connections #3
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.View attachment 4239601View attachment 4239602
I use contact spray cleaner than small cleaning tool design for clean,once dry little Deoxit grease....yet to have problem with tractor or snowplow.
/ Cleaning Harness connections #4
I had a similar problem on a piece of equipment. Sprayed all the connections with a plastic safe electrical contact cleaner then sprayed the connections with fluid film before reconnecting. Solved the bad connection.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
300 gal Fuel Tank (A66408)
300 gal Fuel Tank...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
