Cleaning Harness connections
/ Cleaning Harness connections #1
OrangeJbird
NW WI
3320 w/300cx FEL
What’s the acceptable service department method of cleaning this?
Wiring Harness 6430 Premium
Part Number AL201847
DescriptionWIRING HARNESS, ENGINE/4-CYL. 4VHPC
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.
/ Cleaning Harness connections #3
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.View attachment 4239601View attachment 4239602
I use contact spray cleaner than small cleaning tool design for clean,once dry little Deoxit grease....yet to have problem with tractor or snowplow.
/ Cleaning Harness connections #4
I had a similar problem on a piece of equipment. Sprayed all the connections with a plastic safe electrical contact cleaner then sprayed the connections with fluid film before reconnecting. Solved the bad connection.
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
THIS WILL BE A TIMED ONLINE AUCTION! (A65640)
THIS WILL BE A...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
