Cleaning Harness connections
/ Cleaning Harness connections #1
OrangeJbird
NW WI
3320 w/300cx FEL
What’s the acceptable service department method of cleaning this?
Wiring Harness 6430 Premium
Part Number AL201847
DescriptionWIRING HARNESS, ENGINE/4-CYL. 4VHPC
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.
/ Cleaning Harness connections #3
I’m getting low and  variable voltage readings in the cab in various codes seating low-voltage in causing the SCVs to stop working and I think it’s due to connector corrosion somewhere.  alternator output is steady and battery stays charged.View attachment 4239601View attachment 4239602
I use contact spray cleaner than small cleaning tool design for clean,once dry little Deoxit grease....yet to have problem with tractor or snowplow.
/ Cleaning Harness connections #4
I had a similar problem on a piece of equipment. Sprayed all the connections with a plastic safe electrical contact cleaner then sprayed the connections with fluid film before reconnecting. Solved the bad connection.
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
2844 (A58376)
2844 (A58376)
40’ Shipping Container (A64047)
40’ Shipping...
Cat 262D Wheeled Skid Steer (A64047)
Cat 262D Wheeled...
2023 New Holland T5 120 Tractor (A64047)
2023 New Holland...
