CK 30 4 wheel drive
/ CK 30 4 wheel drive #1
VFI540
I am the only one that that a hard time getting my CK 30 into 4 wheel drive. I have had times when I needed it now and the only way to get it in is use my foot or go look for help.
VFI 540
/ CK 30 4 wheel drive #2
VFI 540
Mine was a little stiff at first. The more I used the tractor the easier it was to engage the 4 wheel drive. Now it usually goes in the first try. If not, I just bump the HST pedal a smidge and it will slide right in. If it's really hard to engage, try lifting the front wheels off the ground (if you have a FEL).
Don
/ CK 30 4 wheel drive #3
VFI540:
Welcome to TBN :)! TBDonnelly has good suggestions. Jay
/ CK 30 4 wheel drive #4
As you are attempting to engage 4wd, turn your (steering) front wheel back and forth.
/ CK 30 4 wheel drive #5
Mine works easy by hand now after I got under there and sprayed the linkage with lube.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Landhonor 8" Mini Excavator Bucket (A66285)
Landhonor 8" Mini...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
72in. Land Plane (A65640)
72in. Land Plane...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
