CIRCULATOR PUMP REPLACEMENT
/ CIRCULATOR PUMP REPLACEMENT #1
Brimfield
Mass
Kubota L 3800
I have an outdoor wood boiler. After 8 years the Taco 009 circulator died. I am looking to find an energy efficient replacement. The height it has to pump is around 14 feet, boiler to the basement. I use a heat exchanger so I don't need to pump up three stories. I'm just trying to lower the electric bill some. Anyone know of a good pump for this?
/ CIRCULATOR PUMP REPLACEMENT #2
So the Taco 009 is 1/8 hp and draws up to 1.4 Amps at 115 volts or approximately 160 watts.
To use less energy you would need a smaller motor.
Grunfos has some as small as 1/15 hp.
This link has several different pumps that could be considered;
Circulator Pumps
/ CIRCULATOR PUMP REPLACEMENT #3
Unless you pay a super high per KWH rate, I don't see how 160 watts intermittent running would impact you electric bill all that much. The Taco I have is a 3 speed model and I usually run it on low.
The circulator is not intermittent unfortunately, this is on a outdoor wood boiler circulating 24/7 . It adds up over time, so now that I need to change it I'm looking at the options for a more efficient one.
Circulator Pumps
Thanks for the link and info, good place to start.
/ CIRCULATOR PUMP REPLACEMENT #5
+1 on the Grundfos.
Since you are running a loop, it really isn't up 14', it is about how many gpm that you need/want. Faster will equilibrium the temperatures sooner, but may be less efficient, depending on your heat exchangers.
All the best,
Peter
/ CIRCULATOR PUMP REPLACEMENT #6
Not sure they will work for your application you would need to check the pump specs but we replaced Taco 007 (and a different model) & are now using the Taco Viridian pumps on our radiant system... super quiet & efficient pump... the ones we have max out at .54 AMPS / .44 Watts
Well I found it Taco Viridian 1816 variable speed 4-44 watts. I even got a cartridge to rebuild it when it goes. I got lucky that it died late march and not in February at - 5* , prime time for my OWB to break down. For now I'll fix it and shut down for the season.
POLY WATERING TROUGH & SUCTION HOSE (A64278)
POLY WATERING...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
7002SFL (A61572)
7002SFL (A61572)
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
BUSH HOG 4R48" BEDDER (A64278)
BUSH HOG 4R48"...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Anthem...
