CIRCULATOR PUMP REPLACEMENT
/ CIRCULATOR PUMP REPLACEMENT #1
Brimfield
Mass
Kubota L 3800
I have an outdoor wood boiler. After 8 years the Taco 009 circulator died. I am looking to find an energy efficient replacement. The height it has to pump is around 14 feet, boiler to the basement. I use a heat exchanger so I don't need to pump up three stories. I'm just trying to lower the electric bill some. Anyone know of a good pump for this?
/ CIRCULATOR PUMP REPLACEMENT #2
So the Taco 009 is 1/8 hp and draws up to 1.4 Amps at 115 volts or approximately 160 watts.
To use less energy you would need a smaller motor.
Grunfos has some as small as 1/15 hp.
This link has several different pumps that could be considered;
Circulator Pumps
/ CIRCULATOR PUMP REPLACEMENT #3
Unless you pay a super high per KWH rate, I don't see how 160 watts intermittent running would impact you electric bill all that much. The Taco I have is a 3 speed model and I usually run it on low.
The circulator is not intermittent unfortunately, this is on a outdoor wood boiler circulating 24/7 . It adds up over time, so now that I need to change it I'm looking at the options for a more efficient one.
Circulator Pumps
Thanks for the link and info, good place to start.
/ CIRCULATOR PUMP REPLACEMENT #5
+1 on the Grundfos.
Since you are running a loop, it really isn't up 14', it is about how many gpm that you need/want. Faster will equilibrium the temperatures sooner, but may be less efficient, depending on your heat exchangers.
All the best,
Peter
/ CIRCULATOR PUMP REPLACEMENT #6
Not sure they will work for your application you would need to check the pump specs but we replaced Taco 007 (and a different model) & are now using the Taco Viridian pumps on our radiant system... super quiet & efficient pump... the ones we have max out at .54 AMPS / .44 Watts
Well I found it Taco Viridian 1816 variable speed 4-44 watts. I even got a cartridge to rebuild it when it goes. I got lucky that it died late march and not in February at - 5* , prime time for my OWB to break down. For now I'll fix it and shut down for the season.
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2017 Land Rover Discovery Sport AWD SUV (A64557)
2017 Land Rover...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2022 EZ-GO ELITE...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
