chimney liner installation
   / chimney liner installation #11
The liners are mostly good even flex. If you go over to the Hearth.com proably 90% of those guys are running flex liner in an application like yours. Pretty much any source is good.
Even the queality ones say NO metal brush, even ridged liners are NO metal brush. I have a flex at my farm house and i dont think i could try to "tear" it with anything short of poking a screw driver through it, never your hands or a metal brush.Its not that its going to tear, but that the brush with create scratches in the metal over time and create spots where rust will start. Trust me and actually read the manufactures wedsite on what they recoment cleaning. Even the expensive SS pipe i see for class A chimney says poly brush only.
Just a word to the wise so you dont go jacking up your $4k pipe you spent 3 hours installing.
   / chimney liner installation #12
Good Mornin Lou,
I would think I woud attempt it myself based on the info you gave in your first post. A straight shot with god access...
Just a couple of thoughts I came up with. Try screwing two lengths of pipe together at a time, and possibly a safety rope attached to a t-bar running through each section of pipe until your at the proper length. Possibly some type of clamp at the top of the flueuntil you can make your bottom connection. Then a flue cap screwed into position on the stove pipe, supporting the weight on the top of the flue...
Also an extra set of hands wouldnt hurt either ! ;):)
   / chimney liner installation #13
I would suggest you first check local codes for the proper installation.
When I changed over from an open burning fireplace to an airtight insert, the company installed a solid stainless steel liner and connected it to the stove with a flexable stainless steel piece which was about 3 feet long. Three stainless steel pipe (solid) were screwed together and lowered down the chimney and was then connected to the flex pipe and then the stove. The pipe was one inch smaller than the stove size and by code where I live you can reduce only one inch.
Your insurance company will insist on a proper install according to all local/national codes or you could void your insurance.
Fred
   / chimney liner installation #14
Mine appears to be a clear shot. The liner I'm thinking about is 6" so should slip down 7x11 flue. I see no "shelves" of cement or brick to get caught on. I have no room for insulation but I think chimney is tall enough for good draft. I need something that is lifetime and not having to be replaced in 10 or 15 years.
I used to replace these for a living and would hate to see you have trouble after your repair. You may have a good draft but mainly what the insulation is for is for it to keep the temperature up to the point where creosote doesn't develop. the steel cools really quick like when your fire dies down at night and this is the point where the creosote start to develop, then the next time you fire it up good and hot you get a chimney fire. Any certified installer will wrap it with ceramic insulation and then put a stailess steel mesh around it to protect it. stainless steel chimney liner - Bing Images
The link will open up a picture of what it should look like.
   / chimney liner installation #15
You'll see alot of photos of people just putting straight pipe in with no insulation, usually the reason for this is they dont want the bust out the old clay liners, the hardest and dirtiest part of the job. It usually take a few hours just to do that. The primary reason for the poly brush is you dont want to scratch the liner and give the creosote somethnig to stick to.
Absolutely correct. I myself didn't want to do this. Even if I put in a 5.5" liner and pour in the insulation, that still is only giving me a little over 1/2" on the narrow side unless I tuck the liner closest to the house. The pour in type is like cement so I need a liner good enough where i won't need to replace it.
I'm not using insulation and here is why: 1/2" of insulation might keep the steel tube warmer but for how long? The heat radiating from the ceramic tile should also do this as long as the liner is not covered. I think its much more important to size the liner correctly. My present 7x11 ceramic liner has been inspected and deemed in excellent shape. Had I not considered another appliance that calls for a 6" flue, I would not have to do anything. I think a liner has much to do with insulating the pipe from heat spread of a chimney fire. With a smooth surface of a rigid liner coupled with an epa appliance that burns smoke, creosote problems should be mitigated to a large extent.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
John Deere 7130 (A50120)
John Deere 7130...
Exmark Lazer Z (A50121)
Exmark Lazer Z...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
