Chest Freezers
/ Chest Freezers #81
Growing up we always had ice cream in the freezer, often homemade. Now that I have my own freezer, there is never ice cream in it. Too much temptation. I try to keep meat, veggies and fruit in it, that is pretty much it.
/ Chest Freezers #82
Hey, I just bought a quart of Tillamook. You trying to give me the "guilts"? I have a 32 cu ft chest freezer down in the basement. Used it the first year we were here. For all the veggies from the garden. Only used that one year. Sat down there the 37 years since. I had it lowered into the basement with the semi boom truck that came and off-loaded our house pallets. PanAbode cedar home. I don't even know if it will fit out thru the basement door now. Might need a chainsaw.
/ Chest Freezers #83
With our nest becoming empty-er :), we can and did put the new freezer in a bedroom (we have 3 spares), and the room is still usable as a guest room.
Me personally, I would never put a deep freeze of any size on anything but a concrete floor. Mine is on what used to be a concrete porch many years ago before they enclosed it long before I bought this place.
/ Chest Freezers #84
I'll see your sirloin, and raise ya a Porterhouse :D
enhance
enhance
Dang, I'm lucky if I can score 3 quarters of a cow at the beggining of the year.
I've got to ask, is the window shaker the only thing you're using mechanical for cooling in the meat locker between 30 and 40 F? Or what temp do you keep the room?
/ Chest Freezers #85
Yes, that is the only refrigeration for the cooler.... a 10,000BTU window AC unit, combined with a "Coolbot" controller.
You take the thermostat probe wire from the AC unit, tape it to the heat wire from the Coolbot, then set the Coolbot for the room temp you want, as low as 33, and it 'fools' the AC unit into running until the room reaches that temp. Most AC units won't run below the low 60's otherwise.
Cheap way to make a walk-in cooler. Mine is 6x6 with 4" foam walls/ceiling covered with some white fiberglass board. The door I scored (Craig's List) off an old commercial cooler removed from a school.
Lot here about the controller, building a cooler, AC sizing, etc:
Walk-in Cooler for Agriculture, Brewery, Floral, Hunting, etc
/ Chest Freezers #88
If you are in an area with humidity or dampness, I would not put any appliance directly on a concrete floor. I would suggest wood blocks to keep it away from the dampness.
/ Chest Freezers #89
Why wood? It holds moisture just like concrete does. I can see it if you're after air circulation under the freezer, but anything including concrete pavers would work. If you're after isolation from moisture, wouldn't you need a waterproof membrane like plastic?
/ Chest Freezers #90
You just need an air gap so the moisture evaporates
/ Chest Freezers #91
It's on casters about 2" or maybe a bit less. Plenty of air gets circulated under it.
I just don't want it on a wood floor or carpeting of any kind in case it loses power and leaks somehow. I doubt you'd ever get that stench out of wood.
/ Chest Freezers
My freezer is sitting on commercial broadloom just at the bottom of the basement stairs. Eventually, I will put it in the fruit cellar. I generally keep everything off the ground, but it also makes a nice place for dirt, dust and spiders to accumulate.
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
TIRE RACK WITH TIRES (A68842)
TIRE RACK WITH...
2 WHEELBARROWS (A68842)
2 WHEELBARROWS...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2018 FREIGHTLINER...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
