Checking filled tires pressure
/ Checking filled tires pressure #21
This one will work Amazon.com
I used to have two of them, read - destroyed them by using on my filled tires, no mater how long i rinsed them after use, by the next time they were unusable. Also, used one from HF with long hose which also had the same outcome. I was not able to remove all the beat juice from inside no mater how long i was messing with them. Now i check the pressure by the look (really scientific ;))
/ Checking filled tires pressure #22
Milton model S-298 is designed for use on fluid filled tires. You do need to rinse it out with warm water after use or beat juice will set up and make it sticky.
You probably mean S-928. It is exactly one i used to have. Actually still have, but they are useless. they do not show right pressure after exposure to beat juice and prolonged shower exercises.
/ Checking filled tires pressure #23
Today I re-checked the pressure in my R1 tires. I was wrong, the man that put the WW fluid in them set pressure at 12psi.
I jack up my rear tires to check pressure so I don't lose any fluid if the air pressure is so low, the fluid is the only thing supporting the tractor.
/ Checking filled tires pressure #24
Fill fluid is NOT compressible the only thing that is compressible in a tire is the gases (air).
12 psi in a filled tire is the same as 12 psi in a non liquid filled tire. The non liquid filled will ride better as there is more volume to work with so the same deflection of the tire has less impact on the pressure then a tire with 60-70% liquid fill.
/ Checking filled tires pressure #25
In similar thread many years ago))it was recommended to jack up the tire and turn valve on top at 12
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
5' Dearborn Disc (A62613)
5' Dearborn Disc...
