Checking filled tires pressure
/ Checking filled tires pressure #1
ning
Elite Member
Northern California
Branson 3520h
I went to check my rear - filled with scrumptious beet juice - tires.
I parked with the valve at the top last night. Today I figured, press the button to eject what little juice may be left in the valve, check pressure, then fill.
I got about half a cup and stopped.
Did they fill the tire completely? I thought they left an air space?
/ Checking filled tires pressure #2
There is supposed to be a little airspace but it could be filled slightly above the stem.
/ Checking filled tires pressure #3
Filled tires should be checked with stem on the bottom; which requires a different air gauge.
The normal fill is 70%. That is approx. level with the stem; completely filled is not good.
Jack up that wheel position, then check air pressure.
The usual air pressure is 18 PSI for a filled tire.
/ Checking filled tires pressure #4
Mine did the same thing, mostly on one side. I let some beet juice out.
Even with the special gauge I find that I have to rinse out the gauge immediately or the beet juice will start drying inside. I carry a pan of warm water out to the tractor.
/ Checking filled tires pressure #5
I was 100 feet from him when he said it.
/ Checking filled tires pressure #6
With the proper gauge it does not matter where the stem is with the proper type of gauge.
Yes, you must rinse the gauge thoroughly after use or it will become plugged up and useless.
If the pressure is low the weight of the tractor could squash the tire a bit causing the liquid level to be higher than the stem positioned at the top of the wheel.
With a standard gauge I would put some air in it and then to see if I could get it to stop squirting fluid and then let some air out if there is too much rather than try to check them if they could be low.
I set the inflator to 18psi, turned it on and hooked it up and ran it till it was full. Took a couple minutes but not long.
I had a hose extender on it; removed it after and cleaned it; no sign of juice before it.
/ Checking filled tires pressure #8
Why not get an oil/fuel pressure gauge and put a chuck on it?
/ Checking filled tires pressure #9
Curious where the 18 PSI came from for filled tires. Last time I checked pressure was determined by tire size not by being filled.
My understanding is that since there's less air volume to provide shock absorbance, you need to treat the tire differently.
Consider the degenerate case where there's just a spec of air space - virtually the entire tire is filled with fluid. Since the fluid is mostly incompressible, the tire is going to ride really hard.
Ok, that's a degenerate case. Now, decrease the fluid by a cup, add just a bit of air.
Will the tire be bouncy now? Barely. And, if you run 30psi in that one cup space of air, you can barely compress that one cup of air before it's pushing back really hard.
Now at 20% air, 80% fluid, the tire isn't going to behave like you want it to if that 20% air is at (100% of tire full of air) pressure, because every bump on the tire is only acting on the 20% of the volume which is compressible since it can't mess with the fluid.
You have to put less air in, so that the entire tire behaves right... or at least, closer to right.
My guess is that even at 18psi it's still probably going to ride harder than an all-air-filled tire.
/ Checking filled tires pressure #11
Yes filled tires generally ride a little rougher but I have never seen where adding fluid changes the air pressure setting vs running unloaded tires.
I run the run tires on my 2400H at 10 - 12 PSI and they are filled with rim guard. I do not recall what factory spec is. This is my choice and if 18 PSI works for you that is your choice.
/ Checking filled tires pressure #12
Tires should be inflated using the tire load charts for your anticipated loading.
Rear R1 tire pressure will normally run from 10-25 psi.
Here is a clip from Goodyear Titan for a 16.9-28 bias ply tire, with road speeds and loading. Also these are per tire so double that per axle.
Most manufactures will have these charts for your tires.
Also filled or not the pressures are the same.
/ Checking filled tires pressure #13
The left rear on the Hurlimann was way low this spring. When I put the air chuck on the valve with the stem positioned at the top, chloride came out. I knew where the leak was (at the stem) and filled the tire until it "looked right.
Close enough, and no air gauges got messed up.
/ Checking filled tires pressure #14
If the tires are low and sides bulging I add some air until they "stand up."
I've never used a gauge.
You can tell if you got it right by the tread pattern the tires leave in the field.
Just remember not to over do it.
I've been on tractors for close to 60 years. Before that on my daddies lap just steering tractors.
Neighbor had a flat few years back. Guy came from the tire shop fixed the problem, filled and inflated the tire.
He got so busy talking on his cell he blew the tire off the rim. Calcium everywhere.
/ Checking filled tires pressure #15
What is a "special gauge" for filled tires? Link? Name?
/ Checking filled tires pressure #16
Do a search for gauge for filled tires. The ones I have are spring loaded plunger style so must take reading with gauge on valve stem.
Others have a gauge with a piece of hose between gauge and chuck. This keeps the fluid from getting to the gauge.
/ Checking filled tires pressure #17
I did and did not find any "special gauge" and the "gauge with a piece of hose between gauge and chuck" did not work for me. It got filled with the bit juice and plugged the gauge without showing the correct results.
/ Checking filled tires pressure #18
/ Checking filled tires pressure #19
Milton model S-298 is designed for use on fluid filled tires. You do need to rinse it out with warm water after use or beat juice will set up and make it sticky.
/ Checking filled tires pressure #20
I had a special gauge and it was messed up after a couple of uses. I ended up overfilling the tire and had to let air out which made a huge mess.
