3-Point Hitch Check chains on an L2650
/ Check chains on an L2650 #1
spudbud
Riverside, IA
John Deere 955
My elderly father recently bought an older L2650 with a MMM. After purchase we realized the check chains on the 3PH that control sway of implements attached to the 3PH had been removed by a previous owner. There is a bracket for the MMM bolted to one of the arms so perhaps the chains were removed because of this??? I checked with the local dealer and they want over $100/side for new chains! Seems pricey to me. Anyone have any experience with this or know of a place to buy these used? Or make your own? Thanks for any advice.
/ Check chains on an L2650 #2
I bought an after-market pair for my B2150 for around $20.00 each I think from Agri-Supply. The trick is matching the limits, left and right, and getting the appropriate fittings on each end. Mine matched perfectly and were heavier-duty than the ones that came on the tractor.
If you're interested, I saved the ones I bought when I traded the tractor for a new B2630, which has a slide with pins. If you want to measure the openings in the clevis end, the required length, and the size of the hole in the lift arm, I'd be interested in selling them to you.
fschukar@gmail.com
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
